I see that you offered a solution, but don't see the solution on my screen.
Where did it go?
I have a Kingston 2GB SD card that works fine in my digital camera, but I can't read the card using my computer's card reader. My computer's operating system is XP Media Edition
Different generations of hardware may be at the root of this. Pages below may be of help.
How to Transfer Pictures from Camera to Computer Without Software
https://support.usa.canon.com/kb/index?page=content&id=ART138112
https://www.dpreview.com/forums/thread/3932763
Computer cannot detect SD Memory card on USB Solved Closed
SOURCE: Cannot read Kingston 2GB SD card on my computer
Dear,
All just try this trick
Connect your phone to PC and try to acces the card on PC. Now format the card but, take the backup of data before formatting the card.
Regards,
Rakesh Kumar
SOURCE: Can I use Kingston 2GB micro SD in Nokia 2680
the nokia support micro SD then you can introduce in the slot on the side on the fone , and that's it your done
SOURCE: Hi I have a SD 1.0 GB Kingston camera memory card.
I have the same problem once i reinstalled windows and it worked for me.
SOURCE: Hello.... I have a Kingston G2
The device should not need a driver. These devices require USB 2.0 if you are using them on older systems that only have USB 1.x, they may not function. If you are using a newer PC, there may be something wrong with the port... try a different port.
