D-Link Securicam Network DCS-950G Wireless Internet Camera Logo
Posted on Sep 28, 2008
Currently 7 people living in flat - any new people that move in cannot connect .
Anonymous
Level 1:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Sep 30, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
8
Questions
0
Helped
2144
Points
8
The most likely problem is that the software that the camera uses is limited as to the number of simultaneous users. You could upgrade to a simple Pelco or Dedicated Micros server, and then the number of users can be in the hundreds, I believe. Let me know through a post if this is not the problem.
1helpful
How to replace throttle cable on a 1981 Chevy G30 /350ci campervan ?
check and test connections at carb and foot pedal since cable rarely fails ------order new one --disconnect old one take photo or draw out route and connections ---feed new through fire wall ---
1helpful
How do you put your phone contacts to your sim card
There is no SIM manager program on Windows Phone.
With Windows Phone, all your contacts are automatically sync'd to your Windows Live account online.
If and when you get a new phone, set it up using the same Windows Live ID you are currently using and all your contacts will sync up to your new phone.
Will my hp pavilion a 420n support a 19" flat screen monitor
I have to assume you are currently using the larger size called a tube type monitor and would like to have an LCD or flat screen type monitor connected to your computer.
To connect to new LCD flat screen monitor to your computer would be exactly the same connection as what you are currently using.
The only problem you could run into is the connector itself. Some of the flat screen LCD monitors do not have the older style connector called VGA, usually blue called DB15, because it has 15 pin connector. They may have only have the newer style called a DVI type. Some do have both types.
Please be sure the LCD you want has the older style DB15 connector to connect to the rear blue VGA input of your compter.
Good Luck
How to reset the hager EH711? Currently it is set to turn off the light at 7:30am and turn on at 7:30pm. I want to turn on at 7:30pm and turn off at 7:00am. thank you in advance.
Open following link for Hagar timers:
http://waterheatertimer.org/Hagar-timers-and-manuals.html
Hagar EH711 has segments located around the analog dial.
The dial rotates as time passes and the segments move tiny lever that turns Loan on-off.
The segments are pushed down and outward or up and inward to set on-off times.
The timer can be wired a couple different ways, so setting the segments up or down depends on how it was wired.
If you look at dial on your timer and see how segments are set now, that will give you the correct information.
If segments are down between 7:30am and 7:30 pm, then move those segments up-and-inward.
To check the timer after moving your segments, you can manually rotate dial clockwise and watch the load turn on-off. To set current time, rotate dial until current time lines up with arrowhead located on inner dial.
The slide switch has 3 positions. 0 = ON all the time; 1 = OFF all the time, and Auto = timer turns on-off depending how segments are set.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
I have a 3G dongle (ZTE MF626) and can not get access to the internet. I tried with two Laptops via Wireless. One with XP and the other with Windows 7. The wireless is recocnizing the ESR 6650 but can not...
Try this link
The Connection Manager installed from the USB modem does not include Windows 7 Drivers.The Connection Manager M03 does include Windows 7 drivers.
For Windows 7 support do only one of the following two options:
a) Update your currently installed Connection Manager using the Windows 7 driver tool or...
b) Install the new Connection Manager (M03) after un-installing your current version.
I have a Philco Dryer and need to buy a replacemet belt. The code on the belt is OPTIBELT - RB 7 EPH 1904 416001602 Made in Germany. I have looked everywhere for it and can´t find. I currently...
i have a new out of box belt witht he same # you need. I will have it on ebay soon if you are interested let me know. It wil be $40 plus shipping.
Oct 05, 2010 • Dryers
2answers
My acer wont boot up
Check your power outlet, use UPS and then connected ur PC to it.
Top D-Link Home Security Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a D-Link Home Security Expert? Answer questions, earn points and help others
