SOURCE: MAIN HOUSE FUSES TRIPPED, RESET, OVEN AND GRILL WILL NOT HEAT UP
It would appear that the tripping of the switch has caused some kind of short within the cooker. I would look for the continuity of the heating element.
Most likely the wires leading to the heating element have burnt and will need replacement. If you are comfortable with attempting a DIY, well and good. You will have to open the back panel to access the said wires. It should be easy enough to identify..it will be the wire leadingto the heating coil.
If , however, you are not familiar with these kind of things, I would recommend getting a repair guy to do it for you.
Cheers and good luck with the repair!
IrishDruid.
SOURCE: trying to replace main oven bulb: cover jammed
Try heating it up with a hair dryer or similar if that does not work then you will probably have to break the glass cover.
SOURCE: Oven blew a fuse
The POP sound normally indicates a short circuit fault (as opposed to overload) you need to have it looked at by a competent person.
SOURCE: Belling XOU252 Single Oven Trips Fuses Repeatedly
Hi.
Probably a faulty element, if you feel competent enough, disconnect the feed to the elements in turn, this should eliminate the problem.
Good luck.
SOURCE: bottom oven not working
A tripped breaker or blown fuse on an electric oven or cook-top, combined with an element that has stopped working, is usually a sign of a shorted, then blown (if the fuse or breaker no longer fail) element.
If you know how to use an ohmeter, you can pull the element, disconnect the wires from each end, then measure the resistance between each end of the element, and each element to the outer sheath.
A good element has just a few ohms of resistance between the wire connection points, and infinite resistance from the wire connection points to the outer sheath. Any readings other than that means the element is bad and need's to be replaced.
