When i switch it on ,it begins nokia welcome but restart again and again.what should i do with it?
I switch my phone on,i see nokia welcome.after some seconds it gets off by itself and restart.it happens as much as i take battery out.whe i wana unlock it ,it suddenly hangs and restart by itself.help me to solve the problem:(
Welcome to Fixya first you should reset your nokia 2690.for that go to settings click on restore factory setting click on restore settings only click on continue put security code the default code is 12345 after then restart your mobile automatically.
Now again, click on settings click on connectivity click on bluetooth click on on message appears bluetooth switched on that's sit.i hope it will work fine.
YOU CAN FORMATE YOUR MOBILE BUT IF DOES NOT WORK THEN ITS A NOKIA SOFTWARE PROBLEM THAT MEANS THE NOKIA SOFTWARE IS CORRUPTED AND IT NEED TO BE RE-INSTALL IT GO TO NOKIA REPAIR CENTER THEY WILL DO IT
As you start, the Security Warning window appears. Select Run to begin downloading the installation file. When the download is complete, select Run once again.
Welcome and introduction window opens, select Continue installation to continue.
In order to continue installation, accept the terms and conditions of the license agreement and select Next.
You can select a folder for the installation of Nokia PC Suite. Then, select Continue installation.
Select Continue installation once again to start installing Nokia PC Suite. The installation may take several minutes.
Select Finish to complete the installation.
After the installation is completed, you need to restart your PC for
the changes to take effect. You can choose whether to restart your PC
right away or later.
The Problem with Nokia 3110c – Switching off and automatically restarting
This is what happens. Nokia 3110 hangs, gets switched off and
restarts randomly. More often, it restarts around 3 times or so and
then gets switched off.
Possible Causes and Solutions
Cause 1 – Phone Memory Full – Nokia 3110c mobile phone has got 9MB of internal memory. Solution – Keep the free space between 350 to 500
KB, so as to keep things running smoothly on your phone and prevent
Nokia 3110c from restarting. Cause 2 – Changing Themes – Some people have
reported that the phone restarts automatically when they try changing
display themes on the phone. Solution – Don’t get your phone loaded with too
many themes downloaded from the internet or atleast, don’t switch
themes frequently. These themes, mind you, also load up things into
your already falling Nokia 3110c phone memory. Cause 3 – Memory Cards – Some people have reported that Nokia 3110c restarts due to some issues with the memory card. Solution – Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue. Cause 4 – Transferring data via Blueooth / USB data
cable (or) Updating Music Library – A few people have reported that
their Nokia 3110c mobile phone restarts when updating the music library. Solution – Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone. Cause 5 – MP3 files Solution – This may seem dumb, but consider
converting all your MP3 music files to WMA and then store them on the
memory card. Some users suggested this.
Also try this:----- It ll work . you dont need to go 4 the firmware v5.05 If ur phone restarted 3 or 4 times and switched off automatically. Try this method 1] Remove the battery and Micro SD card 2] wait about 5 minutes 3] Then switch On the phone WITHOUT the memory card
Now ur phone working well without restarting
4] Then you must restore Factory settings frm the Settings Menu [default security code:12345] {i know most of people have done this thing,but remember u have 2 go with the correct order.Unless it will not work.OK}
5] Now apply a theme. The theme's size should be below 100kb
6] Now ur phone working fine without the Micro SD
7] Then wait about 5 minutes and Switch off ur phone
8] Remove the battery and insert the Micro SD {Don t Format the memory card}
9] Switch On ur Nokia 3110c phone. 10] Now Keep ur free Phone memory space [Not the memory card's free space] between 470kb - 499kb.
Now surely ur 3110c working fine about 5 months.During these time u can 1] Send/receive any file via bluetooth. 2] Enjoy Music,video, GPRS,Yahoo Go .....etc 3] Also u can Update music library anytime. but remember below DONTs 1] Don t try to change themes.{u have to stick with a theme} 2] Charge ur phone in ON mode 3] Dont fully discharge the battery 4] Start charging ur phone when there is only a bar on Battery indicator 5] Dont erase calender notes
Make sure about above 5 Donts
Dont worry if ur phone restarted once.{U know the problem is restarting several times and automatically swiched off.}
After 4 or 5 month there is a possibility to occur the problem again. if so Follow the above steps again. Good luck To be frank, This mobile has this as a generic problem. As I told, The problem can come back again.
hey i have a solution but its quite rough though... take out all your memory card and sim card and battery... then without the battery press the on button. just put in the battery and keep holding the button. if it still restarts then take out and put the battery in again until it will start. this really works as it works for me 5 times when i had this problem. but the only thing i'm scared is that it might damage your phone. but once you have this problem your music player will be spoilt already. my music player was also spoilt but it works twice. now it doesnt work though. im not sure about music player
To format N 73 Cellular Phone Steps are shown below
You can remove the mmc but keep the sim card and restart your phone.
Then press the keys *#7370#.
The phone would ask a confirmation.
Select yes.
Then it will ask for a code.
Type the phone lock code (the default code is 12345).
There you are! your phone will restart with all the phone memory formatted.
Tips
Also remember that you can reset your phone but not loose any of
your personal files (I.E restore the settings that came when you bought
the phone while keeping contacts etc) by following the above procedure
but using the code *#7780#
Warnings
Don't apply these steps if you are not sure what you are doing.
Make sure you have enough battery power before beginning this procedure.
