The vertical lines appeared on my lcd screen, 1 line first then it adds up, as of now i have at least one hundred vertical lines
SOURCE: Two vertical lines on my compaq presario (M2000)
Try changing your screen desktop resolution to a
different value. If you still have verticle lines, then try changing
the color depth from 32bit to 24 or 16. If the problem remains your
display adapter has completely failed. It has failed to compute column
row addressing math.
Naturally, you would want to find and
install the latest drivers for your display adapter with the hope that
the failure is in the software driving the display adapter and not an
onboard chip. If updating your drivers fails to resolve the issue you
need to have service performed on your laptop. Most laptops have the
display adapter soldered on the main circuit board and many shops are
capable of replacing this chip set.
Yet, get a quote first as
the cost might cause you to consider an upgrade into a laptop that has
a display adapter that is Direct X 9c or Direct X 10 ready as that will
run most of the new game titles coming out this year.
Let me know if you have any further need of assistance as you run through the above troubleshooting routine.
I do hope this has fixed ya!
Worldvet
SOURCE: two vertical lines on my compaq presario (M2000) laptop
Well, since the line disappear when the screen saver comes on, I"m led to believe that all the hardware side of the equation is OK. To put it simply, if there was a malfunction in the video (chances are) it would affect that too.
I would update (most likely available as nobody usually does this) the firmware for your video card. So identify the card EXACTLY, from documentation, or from the build list on the manuf. website, goto the manufacturer, say, ATI, and find the firmware there, where you will also find instructions to install it.
Then, just to be sure, I would update the video driver for Windows, in a similar manner to the instructions above.
If, despite all the above you still have a problem, then its time to get the computer serviced.
Good luck,
Erik.
SOURCE: HP Compaq Presario V5000 LCD Problem
I have the same problem. I thought the problem was due to a loose cable so I opened the computer up only to find out the cables are all good. I still haven't found a solution
SOURCE: My Compaq Presario M2000 has
It's possible the cable between the motherboard to the display either got pinched or is slightly disconnected at either end. It is also possible that temperature fluctuation damage could of occurred. Or, it was just a defect in the screen. Sadly, there isn't anything you can do cheaply to resolve it as screens are usually more that $150. Labor to have that installed easily brings the process into $300 territory.
