The set up says it couldn't find the harddisk because you need to slip stream the harddisk driver into the windows xp cd where as in the normal setup cd's it is not present.
You need to download the SATA AHCI controller driver and slip stream it in to your windows xp setup ..
You can find the information in detail on how to slip stream from the website below:
Method 1: Perform a clean install of Windows XPA clean installation consists of removing all data from your hard disk by repartitioning and reformatting your hard disk and reinstalling the operating system and programs to an empty (clean) hard disk. For more information about important things to consider before you partition and format you hard disk and how to partition and format your hard disk by using the Windows XP Setup program, click the following article number to view the article in the Microsoft Knowledge Base:
313348 How to partition and format a hard disk by using Windows XP Setup programTo perform a clean installation of Windows XP, follow these steps:
Back up all important information before you perform a clean installation of Windows XP. Save the backup to an external location, such as a CD or external hard disk.
Start your computer from the Windows XP CD. To do this, insert the Windows XP CD into your CD drive or DVD drive, and then restart your computer.
Note To boot from your Windows XP CD, the BIOS settings on your computer must be configured to do this.
When you see the "Press any key to boot from CD" message, press any key to start the computer from the Windows XP CD.
At the Welcome to Setup screen, press ENTER to start Windows XP Setup.
Read the Microsoft Software License Terms, and then press F8.
Follow the instructions on the screen to select and format a partition where you want to install Windows XP.
Follow the instructions on the screen to complete the Windows XP Setup.
If you have successfully installed Windows XP, you are finished.
The BIOS in your laptop has detected the SATA hard drive as "Fixed Disk 0" this is normal. If you are trying to install Windows XP on this laptop, XP will not detect this hard drive because it does not have the SATA driver included in the XP installation CD. For instruction on installing XP on your laptop with a SATA hard drive, please click on this link and follow my instructions :- http://www.fixya.com/support/r4335035-installing_windows_xp_sata_hard_drive
That is because it was designed for Vista not the obsolete XP. There are no hard drive drivers suitable in XP. Re install Vista or install Win7. Hope that helps.
A clean installation consists of removing all data from your hard disk by repartitioning and reformatting your hard disk and reinstalling the operating system and programs to an empty (clean) hard disk. For more information about important things to consider before you partition and format you hard disk and how to partition and format your hard disk by using the Windows XP Setup program, click the following article number to view the article in the Microsoft Knowledge Base: 313348(http://support.microsoft.com/kb/313348/ ) How to partition and format a hard disk by using Windows XP Setup program
Post back if it is not working we will be happy to help you.
Thank you.
Cheers!!!
If the install cannot detect the hard disk then the hard disk is faulty and needs replacing or the disk controller is faulty.
You can check if the hard disk is faulty by :-
Go into the BIOS and check if there a hard disk diagnostic.
If not then remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port.
If this computer see it as an external hard drive and you can view the contents of the drive then it is OK and the fault is the disk controller on the laptop.
To setup XP.
You insert the Windows CD and boot up the laptop with the CD.
You have done this correctly to get the hard disk error message.
If you are trying to install Windows XP in latest Notebook, it will not be able to detect the Hard Drive since all the latest Notebooks are shipped with SATA Hard Drives and by default and Windows XP will not be able to detect SATA Hard Drives by default.
If you are having a Intel based Notebook, you need to download the SATA Drivers from the link below :
ftp://ftp.hp.com/pub/softpaq/sp36001-36500/sp36132.exe
Find the instructions to create a bootable XP Disk using the SATA Drivers from the link below :
http://www.howtogeek.com/howto/windows/resolving-setup-did-not-find-any-hard-disk-drives-during-windows-xp-installation/
Some copys of windows XP can not detect a SATA hard drive what you need to do is get hold of a later dvd copy of XP only the lastist dvd copys of XP are setup to detect SATA hard drives. It has to be a DVD copy as the CD copys do not detect SATA drives. Find some one with a new computer with SATA drives that has windows XP installed on it and try there copy of XP on your computer. Hopes this helps.
