My IMEI is 353397043372476
I think your phone is asking for network unlock codes. if your phone didnt accept the default even after resetting your phone then your phone must be locked and it should ask for network unlock codes. you can get the unlock codes from your service provider itself. if they didnt provide you you can go for other online providers like Superunlockcodes.com
1. The code *#7780# - Restore factory settings - resets all the settings to the default ( you will not lose any data)
Make sure you back up your data as you will lose all of it when you perform option 2 or 3 on this list. The default code for all operations listed here is 12345
2. *#7370# - Reformat your phone
3. This you perform as a last resort. Nothing else is working. If the phone is not showing any activity, proceed with hard formatting, turn off your phone, hold the following buttons while pressing the power button. (The default code is 12345)
hard reset - hold the following buttons *, 3 (number button) and talk/green key. turn on the phone and do not release those buttons until you see the Nokia boot up screen. once you feel the phone power up you can let go off the power button while still holding all three buttons ( for Nokia 5800XM - use the following buttons to do a hard reset, GREEN/RED/CAMERA keys pressed all at once on power up. this will only work on 5800's that have firmware version 20... and up. )
If these codes are not working the only thing for you to do is contact your Nokia Care Center/Service for assistance. You can find any Nokia priority dealer around you for further assistance.
Regards
Soft reset/reformat - Type *#7370# and the phone's lock code (Nokia default lock code is 12345). Warning!Soft reset wipes the C drive/phone memory!
Hard reset - Switch the phone off. Press and hold three keys together, the green key, the * key and the number '3'. While you are holding these keys, switch the phone on. Don't release these three keys before you see the NOKIA logo.
Warning! Hard reset wipes the C (phone memory) drive.
