I own Canon Pixma MP500 and keep getting a paper jam message when I cannot see any paper jammed. I then get Error code 5110 message. How do I resolve this?
5110 is carriage lift mechanism error.First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.If this not help your printer need service.
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1: Move the printhead carriage back and forth a few times.
Solution 2: Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3: Press the ink pads down in the purge unit. Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Hi
I think it the same code
Hi
Error 6A00
Pixma pro 9000
service error 5110 after paper jam.
BEST QUICKEST WAY TO FIX THE PROBLEM!!!!
DUST BLOWER ALL OVER THE AREA INSIDE
AND TURN IT BACK ON U SHOULD HAVE SOLID
GREEN LIGHT FOR SURE!!!!!!!!
DAMN I CAN'T BELIEVE I BROUGHT THIS SAME PROBLEM
TO SERVICE CENTER THE FIRST TIME!!!
NO MORE WORRIES!!!
Hi
Error 6A00
printer shows error code 5110 and dosn't work
Error code 5110 Canon MP600"
prints 3 to 4 sheet normal and then it stops and gives me error code 5100
