Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN/SPIN if there is excessive water in the washer.
Re-select cycle and select HOLD TO START. If the problem
remains, call for service.
Unplug for 5 minutes then plug back in. This may reset code. You may have to push cancel / pause button for 3-5 seconds. If this doesn’t help, drain pump may have something obstructing it or may be defective
1. Press PAUSE/CANCEL button on the touch-pad twice. 2. Drain the unit, then check that the Drain hose and Drain Pump Filter is clear of foreign objects. 3. Check/ Replace Touch-pad/LED assembly. 4. Check harness connections. 5. Check the CCU.
sounds like central control unit problem, you can check for diagnostic mode operation by setting (door closed) drain/spin, no spin, pressing prewash 4 times in 5 secs pressing prewash again will advance through diagnostic cycle. replacing user interface may also be necessary
Press and hold the "End of Cycle Signal" button to lock or unlock the control panel. The instructions should be printed directly below this button. I hope this helps you.
You need to go to the right, to the end of cycle signal volume control button. Push it and hold it until the beep and it will go off. This is the "child safety" feature so that little ones won't interrupt your wash when they push the buttons. (and they will)
Michell~
according to site an f-01 relates to a CCU issue, remove power for 2 min and try to reset, if not check wiring to CCU(central control uint) all in tact?? replace CCU
ok try first to make sure the detergent drawer is closed tight if its not will stop washer is the door locked some times you have to close them firmly make sure the lock light is on hit pause cancel twice then try washer
When I hit pause/select it powers off. Thanks
