When making a copy form the document glass (not through the feeder), we are constantly getting the message" reposition original". This message does not go away regardless of whether we reposition the original or not. Copy size is standard 8/12 x 11. What is going on?
SOURCE: konica minolta bizhub C252 printer Problem
You should be able to get Konica Direct to take care of it.
SOURCE: where is the volume setting for the Konica Minolta
Touch Utility/Counter key
Select User Management
Controls for sound (beeps) and volume are located there
SOURCE: desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
SOURCE: how to scan to smb with konica minolta bizhub 250
create a folder on the pc you want to scan to and share the folder on the network. This must be done or the printer will not see the folder. Then register a new SMB user on the bizhub and direct it to that pc's IP and the shared folder.
