The flashing standby light on your Luxor TV can indicate several things, including:
Power supply issues: If the TV is not receiving proper power, the standby light will flash.
Malfunctioning hardware: A malfunctioning component in the TV such as the power supply, main board, or backlight system can cause the standby light to flash.
Overheating: If the TV is overheating, it will go into protection mode and the standby light will flash.
Software issues: A software glitch can also cause the TV to display a flashing standby light.
If the flashing standby light persists, it's best to unplug the TV, wait a few minutes, and then plug it back in. If the problem persists, you may need to contact the manufacturer or a professional repair service for further assistance.
You most likely have a non firing cylinder causing the shake and the raw gas from the non firing cylinder is going into the catalytic converter.It is detected and causing the flashing check engine light.
A flashing check engine light means REPAIR NOW!
Hi Rick:
The typical cause is low oil pressure.
The cause of the low oil pressure is your concern.
- Check the oil level on the dipstick. Make sure it is above the minimum, and not above the maximum.
- If the ooil level is correct and the light still flashes, the next question would be "WHEN is it flashing? Low RPM?
You could have seriously worn components that cause low oil pressure, OR, your oil pump could have problems.
According to Pride's troubleshooting documents the service indicator (wrench icon) will flash when a fault is detected by the dynamic controller.
The number of flashes, followed by a 2 second pause, indicates the issue. You will need to count the flashes to determine the cause and a possible solution.
You will need to provide the model number of the dishwasher. However, the likely causes of the lights flashing are many, including water inlet failure, blocked drain filter, leaking seals causing flood switch to trip. You may want to go to the Hotpoint site and find the manual for your model.
In my case, the flashing glow plug indicator is caused by me replacing the stop lights with LED bulbs. Therefore, a cause for this flashing indication could be a blown stop light lamp. The test for this condition is; while the glow plug indicator is flashing, press and release the break pedal. This should stop the indicator from flashing. Check your stoplights. Or add a load resistor to your LED lamps if you have fitted these.
the lights flashing are not what is causing the transmission to shift badly, the purpose of these lights is to alert you that a problem exists in the electronic system and you need the electronic control system tested to determine the cause of the problem(s), any time these lights flash there will be fault codes recorded in the computer control module, a qualified Ford tech will then look at those codes and give you some idea of what needs to be repaired.
