Printer was shipped to me packed right side down. Must have been droped by USPS. Blk ink tank seal to print head leaked but is not leaking now. Some ink leaked inside printer. Tank still almost full of ink but still much ink inside printer. Ink leaked onto right side of upright paper holder then down to upper paper rollers. Ran along rollers down onto lower paper rollers. Ink on upper paper rollers can be seen when ink cover is opened. Can't get to lower paper rollers. When prints is made blk strips are made from each roller on both sides of printed paper. Q: Can printer be cleaned? With what? How can printer be be taken apart to get to all ink??? OR trash can it? It all works but for the leaked ink.
SOURCE: no BLK and Yellow
More info please mikehuang,
When you replaced ink, did you reset ink settings. Do this if not. Also i recommend a thorough cleaning to make sure ink is running out well and heads are not blocked. cheers lilacgerry xxx
SOURCE: Blinking Lights
Follow HP's instruction listed at the link below.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00405441&cc=us&lc=en&dlc=en&product=445440&dlc=en&lang=en
Post back if this did not help.
& please vote...
SOURCE: ERROR MESSAGE BLK 1CHKSUM FLT on tally t6045 printer
BLK 1 means your black toner cartridge, and I believe the chksum error may have something to do with the memory file. Check out No. 6 under Unrecoverable errors on this sheet.
http://www.tallygenicom.com/support/technotes/3400/error.htm
This is problably something to be sent in for maintenance.
For this error these are the recomendations:
(Try cycling power; initilizing printer. If error persists, maintenance
service is indicated.)
