Hi:
Sounds like you have the wrong polarity in your machine. If you are using flux core wire, make sure to connect your ground clamp to the positive side and your gun to the negative side. Dial the right voltage and wire speed according to wire size and metal thickness.Let me know if this help.
Regards,D.S.
I agree, first check for the correct polarity. It should be easy to check and change. Generally some wing nuts on stud connections somewhere near the drive wheels. Also keep in mind that slower wire feed speed while keeping your heat the same will reflect poorly on how your arc penetrates...generally. You need some wire feed speed to punch that arc into the root of the joint and penetrate. Some times it seems counterintuitive, but that's how it works. The settings on the chart inside of the machine will give you a good STARTING POINT, adjust from there. Wire feed welding is very sensitive to the ground. You must find a way to have a good, solid connection on the ground clamp.
