When i want t boot my pc with cd/dvd boot. i can't enter setup to change settings. and the screen 'll b black.
after 3 or 4 times i reed this message (cmos checksum erroe defaults loaded
press F1 to resum or del to enter setup)
if i press del nothing is new; & when i press F1 the pc start with windows
So you reinstalled the operating system ? then returned to set faisafe or optimised defaults
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or the F2 key Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system (note after you have loaded the operating system you should go back andchange the first boot device to your failsafe or optimized defaults) after windows has loaded your computer will automatically restart it might restart 2 times one to finish the installation the next will be because the operating system is loaded and will boot from your cd during the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaultsor load optimized defaults press escape then press f10 to save to cmos to restart otherwise it will keep booting from the cd /dvd drive hope this helps
(note after you have loaded the operating system you should go back and change the first boot device to your failsafe or optimized defaults) after windows has loaded
failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart otherwise it will keep booting from the cd /dvd drive
This error is not the same as a CMOS Checksum Error, which refers to corrupted values of the CMOS settings, the ones you set through the BIOS setup program. This error means the contents of the BIOS code itself are damaged.
During the boot process you will see on the screen a certain key to press to enter setup Press and hold that key during the boot up process to enter BIOSyou can load failsafe defaultsor load optimized defaults ,press escape then press f10 to save to cmos to restart You will also need to set the time and date
In the main or system setup screen you should be able to see the date and time Using your arrow keys navigate to the date and change the date. Once highlighted on the month, day, or year, press your arrow keys or your page up / page down keys to change the date. hope this helps
Error BIOS ROM CHECKSUM - SYSTEM HALTED. CauseBad Hardware SolutionUnfortunately this indicates that your computer BIOS ROM chip or Motherboard is physically bad. It is recommended that you contact your computer manufacturer or take the computer into local service center for repair. If you wish to repair this issue yourself the motherbard will need to be replaced. This error is not the same as a CMOS Checksum Error, which refers to corrupted values of the CMOS settings, the ones you set through the BIOS setup program. This error means the contents of the BIOS code itself are damaged.
The BIOS ROM chip on the motherboard is probably faulty. It could also be another component on the motherboard.
You should make sure that all of the BIOS settings in the system are correct, by rebooting the system, going into BIOS setup and double-checking all the values hopefully against a recent
If you have reset the CMOS memory you need to go into the BIOS setup screen and reconfigure the BIOS. To do that you need to press a key while the computer is booting. Usually F2 but can be other keys. It should tell you on the bottom of the first screen which key to press to enter BIOS setup. If you don't know the settings the should be one for optimal defaults - use that one. You will also need to reset the time and date. Save, Exit and re-boot and everything should then work. This error is not the same as a CMOS Checksum Error, which refers to corrupted values of the CMOS settings, the ones you set through the BIOS setup program. This error means the contents of the BIOS code itself are damaged.
In the main or system setup screen you should be able to see the date and time Using your arrow keys navigate to the date and change the date. Once highlighted on the month, day, or year, press your arrow keys or your page up / page down keys to change the date. hope this helps you
You should make sure that all of the BIOS settings in the system are correct, by rebooting the system, going into BIOS setup and double-checking all the values (hopefully against a recent
During the boot process you will see on the screen to press delete to enter setup Press and hold delete during the boot up process to enter BIOSyou can load failsafe defaultsor load optimized defaults ,press escape then press f10 to save to cmos to restart click start control panel date and time you can make your adjustments to the date and time from there also right click on the date and time on the bottom toolbar (bottom of screen)you should seeAdjust date and time tab hope this helps you
Diagnosis: The BIOS ROM chip on the motherboard is probably faulty. It could also be another component on the motherboard.
If you have reset the CMOS memory you need to go into the BIOS setup screen and reconfigure the BIOS. To do that you need to press a key while the computer is booting. Usually F2 but can be other keys. It should tell you on the bottom of the first screen which key to press to enter BIOS setup. If you don't know the settings the should be one for optimal defaults - use that one. You will also need to reset the time and date. Save, Exit and re-boot and everything should then work. During the boot process you will see on the screen to press delete to enter setup Press and hold delete during the boot up process to enter BIOS you can load failsafe defaultsor load optimized defaults ,press escape then press f10 to save to cmos to restart hope this helps don't forget to vote
Your PC isn't working, the "CMOS Checksum Error" is a BIOS error. It has nothing to do with the monitor. You have to let the PC load the default settings and try to boot up, if the defaults doesn't work, you have to reconfigure the options in the SETUP program. To enter Setup press "Del" or "F2" in the POST screen.
