Mitsubishi WS-55807 TV Logo
Posted on Sep 28, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MGA CS-2657R/2658R I have a 19" Mitsubishi CS-2657R. It has been fine until today. It was working last night, but when I turned it on today, it makes a screeching buzzing sound with other sound. Picture is fine, the buzzing can't be turned off or down. Any suggestions?
Anonymous
Level 3:
  • Master 934 Answers
  • Posted on Nov 03, 2008
Anonymous
Master
Level 3:
Answers
934
Questions
Helped
504635
Points
2229
Journeygal,
Check The Following Components Off Ihvt pin 3 For Open: R558 P/N 103p338010, D 553 264p338010, L502 321c030010, R521 1.2 Ohm You'll Need A DMM For The Job And Any Cheap One From Radio Shack Will Work.
Bill
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
[email protected]
Car overheats
There could be many causes for a small leak, including foreign debris, small crack or loose hose. Using just water with no antifreeze can damage your radiator in sub 32 temps so always mix with coolant/antifreeze. One temp solution is buying stop leak from a auto part store, another remedy I've heard work is putting black pepper (finely ground) in your system to stop small leaks and it actually works. Good luck.
1helpful
I turn on my Mitsubishi WD-73833 TV and it turns itself off
Lessing of brightness on a DLP set is a sign of imminent bulb failure.
A new bulb is in order.
2003 ford taurus heater fan worked fine last night but won't come on at all today.
I do not understand why people will continue to operate a vehicle when they know there is an obvious problem. They ignore check engine lights until the engine stops running altogether and then are "surprised" when they get stranded in the middle of the expressway in rush hour traffic. Then they blame it on the car!!!
In your case, you have ignored the warning signs of your blower motor failing ("making noise for a couple months"?) and now you are dumfounded as to why your blower motor now does not work at all.....I don't get it....!???
REPLACE YOUR BLOWER MOTOR!
4helpful
My monitor was fine last night, when i woke up this morning it would not come on, the blue light is flashing, help
Press and hold the button, until the monitor turns itself off.
Then, turn it on, and hope that it works correctly.
Mitsubishi VS-5005R big screen
I just finished fixing one of this units and there a few thing that i changed, the voltage regulator and 2 capacitors and as prevention repair i did some resoldering in the power supply and horizontal ckt
good luck
[email protected]
Same Mitsubishi as before. The CS-2657R
The cable box remote is programmable = contact your cable
provider to program to work volume on your Mits.............T.
Mitsubishi CS026201 TV screen problems
If the picture looked good last night
then the Tube is fine. The problem is
Power suply . I think there great tvs.
Made to last .a fair price for repair
is about 80.00-100.00
Mitsubishi CS-35505
Had the same issue. Try hitting the input button on the remote. Then chose aux. 1 option. Worked for ours.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
