Phone calls are going to fax after 4 rings. How do I reset to have calls go to answering machine?
You directed this question at me, but unfortunately I'm unable to provide you with a "real" solution at this time. FixYa has informed me that by providing you with this "solution" your question will then be made visible to other experts; hopefully one of them will be able to provide you with a real solution.
Thank you for using FixYa.
If you have an answering machine connected to the same
line as the fax, set the answering machine to answer incoming calls before the
printer does. Increase the number of rings by a factor of 3 over the answering
machine. For example, if the answering machine is set to pick up on 4 rings,
set the printer to pick up on 7 rings.
If you have a voicemail feature in the same line as the fax, you may subscribe from your phone service provider for a distinctive ring pattern feature. You can program your printer to have a distinctive ring pattern and phone number for incoming faxes.
