SOURCE: fp-7713
press and hold paper tray,zoom down,1 simultaniously you will enter in programe.F will come on display press 6 it will appear F6 press stark key change the value and then start key to exit the program press and hold these keys paper tray,zoom down stop key
SOURCE: Panasonic FP-7113 Plain Paper Copier
Service Time imageunit can be removed with two screwsand remove tank before lifting out. You can remove drum and cleaning blade section yourself 4 screws. Two on the cleaning and two on the removablr pins on the side.Then remove blade with two screws and fit cleaning blade and drum and reinstall.
Service manual for service mode to remove spanner display F9 ??
Cheers Justin
SOURCE: ERROR CODE E340 BLINKS WHEN MY COPIER ON
clean sensor beside drum then switch on machine with white paper on glass.
SOURCE: Panasonic FP-7722 Drum Installation
disingage dv unit lower transport assembly remove blue screw from drum unit take drum unit out remove drum lock towards the front remove charge assemby remove drum reinstall drum remember to apply drum powder and replacement of drum blade is recommended reinstall
Check that all the covers/doors are shut correctly.Does the machine show any lights on the display?
