Question about Sharp UX B700 Plain Paper Inkjet Fax
Memory tx i have a sharp uxB700 plain paper inkjet now it is flashing memory tx what does that mean and how to i fix,also have not been able to receive fax's as of yet i can send but not receive what maybe the problem thks for yr help
  • Anonymous Sep 28, 2008
    thank you for your reply i have rogers home phone which is dial tone>>i thought maybe memory tx was what it was telling me fax was sent but didn't receive it,now it is flashing printing error,it also has new cartridge,been cleaned
    thks for help
    Genius:
  • 2,120 Answers
It means you have a fax in memory that cannot be sent.
Do you have DSL or any kind of digital phone line? Do you have a dial-tone?
Unplug the power cord and re-plug.
Posted on Sep 28, 2008
    New Friend:
My toshiba printer+fax 4511 doesnt work, I send fax but can not receive, can you help me?
Posted on Jul 17, 2012
6ya staff
SOURCE:
I have a fax in the memory and don't know how to print it
Press [START/MEMORY] and the stored documents will automatically print out. If you need the step by step owners manual with pictures, please send me an email to lbrown18062@hotmail.com. Please put "sharp ux b700" as the subject.
Jun 15, 2012 | Sharp UX B700 Plain Paper Inkjet Fax
My fax machine states 'fax RX in memory' and does not receive any faxes?
There is a Fax in memory. Either, the machine has a paper jam, is out of paper, or needs the ink cartridge replaced. Fix the above and the fax will print and the machine should work in Fax mode again.
For a unit with paper and no paper jam, try adjusting the paper stack and check if the unit picks up the paper properly. If you have ink in the cartridge, try cleaning the print nozzles and contacts. If a nozzle cleaning from the unit doesn't work, do it manually. Use a damp cloth (lint-free) and wipe in one direction only. Dampen the cloth with bottled or distilled water for best results. See your manual for pictures.
If you need the manual, try the Sharp site or http://www.retrevo.com/support/Sharp-UX-B700-Fax-Machines-manual/id/310bh149/t/2/ .
I hope this helps.
Jan 14, 2011 | Sharp UX B700 Plain Paper Inkjet Fax
I cannot receive faxes, but can send them.
Courtesy www.brokenfax.com :
Sharp ram clear (most models with LCD displays)
Press function 9 * 8 # 7 then # or * until display reads memory clear, then press start. Best of luck and hope this solves your problem.
Greg
Jul 24, 2009 | Sharp UX B700 Plain Paper Inkjet Fax
Printer problem
It sounds like a bad encoder strip (ribbon cable). Uneconomical to repair.
Sep 25, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Sharp fax machine
I keep getting a "Line Error" canot send or receive a fax. I have a SHARP UXB700
May 12, 2008 | Sharp FO 3150 Plain Paper Laser Fax
Print from Memory
Check and see if your fax has a power save button next to your LCD screen. Pressing it will store everything into memory or you could do a flash memory clear however you will lose everything that is stored in memory(RX and TX only). Press FUNCTION , 9,*,8,#,7 then press start, next press your # key to scroll to flash memory. Press start. This should fix it.
Apr 23, 2008 | Sharp FO 5550 Plain Paper Laser Fax
Sharp UXB700 fax machine
Sounds like a job that sent which requires differnt size paper or just froze up the machine.
What you will most likely have to do is, search your menus and setups, and find memory clear. And run a memory clear process.
There some corruption in the fax machines software that needs reset, That will do it.
You will have to then reset date and time, etc. But that should do it.
Feb 22, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Sharp UX B20 Plain Paper Fax
http://www.sharpusa.com/files/fax_man_UXB20.pdf hope this helps Cops
Oct 07, 2007 | Sharp UX B20 Plain Paper Inkjet Fax
Sharp UX B700 Plain Paper Inkjet Fax Logo
440 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
