You have a bad keypad or a loose wire or ribbon,you can try unplugging it for 10 minutes and see if that helps or unplug it,remove the ribbon that connects to the keypad,plug the ribbon back in and see if that does anything,if not you need a new keypad. next time send the model number so i can help you betterF2
- E0 Shorted keypad (also called touch
pad) 1. Check keypad connector for firm
connection (keypad connects to control board).
2. Press CANCEL. If error code
returns after 60 seconds, replace keypad (also called touch pad or membrane
switch). Some models incorporate keypad in to control board as one unit. In this
case, replace control board (also called ERC or clock).
Read more:
http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Whirlpool
Range / Stove / Oven Fault Codes#ixzz1dikBsooc
