Soyo  26 in. LCD TV Logo
Anonymous Posted on Nov 14, 2011
I need to get this part CPT370WA03c [4C2] [S17X120 =dynamic E150630 [do-uo or vo 94u-0
The grid that conects from the source grid to the lcd screen
1helpful
I shortcircuited the 12v lamps in the baumatic bti675ss-eu island cooker hood, how can i fix this cannt find fuse for 12 v circuit, the number on the printboard is 94U-0
The 12 v circuit is most likely coming off a small transformer that you toasted when you short circuited the lamps. On low voltage like that it usually doesn't have a fuse other than one built inside the transformer.
1helpful
Sanyo lcd-32k40 features
  • Model: Sanyo 32K40 Multi System LCD TV
  • World-Wide NTSC/PAL/SECAM Color System - Watch any video signal on this TV!!
  • World-Wide NTSC M, PAL BG, PAL I, Secam BG, DK/ PAL DK TV tuners
  • 32 inch LCD TV with 3 HDMI inputs and PC input
  • USB input for direct media playback
  • 45,000:1 Dynamic Contrast: While viewing either very bright or very dark scenes, it can be difficult to distinguish main images which blend into the background.
  • Dynamic Contrast dramatically mitigates this problem by adjusting the backlight intensity, providing up to a 4X improvement in contrast.
  • 6.5ms Response Time
  • Widescreen 16 X 9 Format
  • World-wide Dual Voltage 110-240 volts 50-60 hertz
  • HDTV monitor (HDTV tuner required for HD reception)
  • This is a multisystem TV. All Multi System TVs in the market do not have a digital TV tuner: What does this mean?
  • To watch digital channels (ATSC Broadcasting in US and DVBT broadcasting overseas) you need a digital source/tuner like a cable box, digital tuner, satellite service, etc.
  • To get the best quality video on this TV you need a source that has a digital connection like HDMI or component.
  • Wide Screen Mode allows you to watch conventional 4:3 aspect ratio broadcasts in wide screen (16:9) mode.
  • Steady Sound® equalizes volume levels so there is consistent output between programs and commercials.
  • Built-in hidden speakers includes 2 (5W x 2) speakers to deliver dynamic sound.
  • Component Video Input offers the best video quality for DVD (480p and 480i), and digital set-top box (1080p, 1080i, 720p, 480p and 480i) connections.
  • PC Input allows you to connect your PC and display the PC screen on your TV.
  • Surround Sound Audio Effect
How to add items on dropdownlistbox in c#
You can try this:
protected void dropdownlist_DataBound(object sender, EventArgs e)
ddlPrd.Items.Insert(0, new ListItem("-Select-", "0"));
We can dynamically add items to dropdownlist using the Data Source.
sqldatadapter
ada = new sqldataadapter("select * from table",conn);
sqldatatable
dt = new sqldatatable();
dropdownlist1.datasource = dt;
dropdownlist1.databind();
4helpful
2answers
Need lg 32lh30 calibration specs
I think I have a solution involving far less effort. Have you tuned your picture settings? Out of the box, the settings are ok and the presets will do the trick for most. But if you're like myself, you want the best picture possible. Here are my settings:
Picture menu:
Aspect ratio: Just Size
Energy Saving: Off
Picture Mode: Expert 2
Backlight: 35
Contrast: 90
Brightness: 54
H Sharpness: 40
V Sharpness: 42
Color: 50
Tint: 0
--Expert control menu
Dynamic contrast: Off
Noise reduction: Off
Gamma: Medium
Black level: Low
Real Cinema: On [grayed out]
Color Standard: HD [grayed out]
Color Gamut: Standard
Edge Enhancer: Off
xvYCC: Auto [grayed out]
OPC: Off
Expert Pattern: Off[grayed out]
Color Filter: Off
White balance: Warm
Method: 10 point IRE
Pattern: Outer
IRE: [see below]
Luminance: 137
-- 10 point IRE calibration
IRE: [Red, Green, Blue results, respectively, for each IRE point]
100 [-8, 1, -40]
90 [-13, -5, -40]
80 [-20, -12, -40]
70 [-17, -14, -33]
60 [-17, -12, -31]
50 [-17, -13, -26]
40 [-13, -12, -19]
30 [-6, -4, -8]
20 [-6, -4, -10]
10 [2, 3, -1]
Color management system
Red color: 2
Red tint: 0
Green color: -1
Green tint: -7
Blue color: 2
Blue tint: 7
Yellow color: 0
Yellow tint: 1
Cyan color: 0
Cyan tint: 0
Magenta color: 0
Magenta tint: -2
These are taken from CNET.com
4answers
Screen prolem
try to lose the screen then make some clleaning n couple it back if it doesnt work, then suspect the connector
3answers
Samsung tv settings
it depends on what your using it for, adjust colour tones to what you think looks natural, contrast between 80-90, keep sharpness below 30. just have a play around till you find what best suits the source material.
5helpful
7answers
Nintendo ds touch screen
i had the same problem and have now fixed it succesfully the touch screen works like a grid and is overlayed onto an lcd screen so that when you touch the screen it makes a conection within the grid so that the machine knows where you are touching .....if one of these grids are broken you will never calibrate your screen as the ds doesnt recognise what you are touching .....in short the answer is to replace your touch screen
2answers
Samsung LE32R87B
The fact that this is on all inputs suggests that teh screen is faulty, i would bring it back and get it replaced.
Top Soyo Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Soyo Televison and Video Expert? Answer questions, earn points and help others
