SOURCE: all lights are blinking on
One of four things possible here 1: Low water level in container. 2: no disc inserted. 3: disc incorectly inserted. or 4: unit has an internal malfunction, before you send it back, descale unit with scaler and flush clean. All lights still flashing call Tassimo and send it back for repair.
Jim.
SOURCE: Plastic Smell & Taste
take up smoking
and then you will loose you smell and taste.
every thing is made of plastic and aluminum now.
only a stainless pot does not leach plastic cfc into water when hot.
SOURCE: Tassimo machine leaking water underneath
I'm having the same problem with my machine. I rang the Tassimo careline and they told me to descale the machine but, so far, this has only made matters worse. I'm now going to take it back to where I got it from because it's still within its warranty.
SOURCE: manual instructions bosch tassimo coffee maker
hi, this morning I was making a capuccino, and the first part was fine, the expresso was fine, I waited for the light to change colors, open the lid, put disc with the cream in the machine and the green light won't come on, only the yellow on the left hand side and is not working<br /><br />
SOURCE: Tassimo Coffee Maker: Tell me
• All lights will blink the first time you turn on your
machine. This is your cue to prepare your machine for use by
following the quick instructions in Step 1 on separate insert.
• If the water level runs low while you are preparing a
beverage, all lights will flash. Simply remove and refill the
water container, and brewing will continue automatically
where it left off. It should not be necessary to discard the T-DISC
and start over.
• The AUTO light will blink throughout the brewing process.
Some drinks require a pause in brewing as part of the recipe
for brewing your perfect cup - this is to allow the optimal flavors
to unfold and is a normal part of the brewing process. The AUTO
light will continue to blink throughout this process.
HOW TO MAKE A DRINK
• Place the mug of your choice on the cup stand.
• When the STANDBY light illuminates, insert the T-DISC® of your choice
and close the clamp.
• The HEATING light will blink as the brewer heats the water to the
optimal temperature for your drink.
• Once the proper temperature is reached, the AUTO light will
illuminate. When it lights up, press the start/stop button to begin
the brew cycle.
• The AUTO light will continue to flash throughout the brewing cycle.
PLEASE NOTE: Some beverages have a pause in brewing
after the initial influx of water into the T-DISC®.
• The MANUAL light will illuminate when your drink is ready.
