Zyxel P660HW-D1 Router Logo
A
Anonymous Posted on Nov 13, 2011
Whats the address so I can get to the log in screen for my EQ-660HW ADSL Gateway router
I'm Trying to open up the NAT type for Xbox live
Courtney Lomax
Level 2:
Passionate:
Visited the website for 10 consecutive days.
Habit-Forming:
  • Expert 83 Answers
  • Posted on Dec 07, 2011
Courtney Lomax
Expert
Level 2:
Passionate:
Habit-Forming:
Answers
83
Questions
0
Helped
13691
Points
168
Xbox live connection problem
READ AT http://www.fixya.com/support/r7868905-setup_xbox_wireless_network
How do I use my router so I can open NAT on my xbox for xbox live?
1 Make sure your ZyXEL Device hardware is properly connected (refer to the Quick StartGuide).2 Prepare your computer/computer network to connect to the ZyXEL Device (refer to theQuick Start Guide).3 Launch your web browser.4 Type "192.168.1.1" as the URL.5 A window displays
6 For administrator access enter the default admin password 1234 to configure the wizardsand the advanced features.(or if you already changed your password, enter that password)7 On the right hand side of the screen you will see a drop down menu. click on NETWORK. 8 Then click on NAT.9 Find the area to configure Port Forwarding.10 The ports that Microsoft recommends to be open are:88 UDP3074 UDP3074 TCP
It also looks like you will have to set up a static address (I was looking at the .pdf for your particular router) You can do this by editing your network setting on your XBOX console, and then using this address as your "server" address when opening the above mentioned ports on your router.
ftp://ftp.zyxel.com/P-660HW-D1/user_guide/P-660HW-D1_3.40_Ed1.pdf
Nat type is strict i cant play xbox
5 A window displays
10 The ports that Microsoft recommends to be open are:88 UDP, 3074 UDP, and 3074 TCP.
It also looks like you will have to set up a static address on your XBOX (I was looking at the .pdf for your particular router) You can do this by editing your network setting on your XBOX console, and then using this address as your "server" address when opening the above mentioned ports on your router.
I do not know how to change my NAT setting to open on Xbox Live
First of all I would just like to cover the basics of strict and moderate NAT settings. For those interested, NAT stands for Network Address Translation and is used to prevent problems with information being sent over a shared network.
With the XBOX 360, Microsoft have defined three categories of NAT. These are:
1. Strict
2. Moderate
3. Open
You can see the NAT level for your XBOX Live connection by going into your
1. System blade
2. Network Settings
3. Test Xbox Live Connection
For you question on how to open your NAT setting follow the steps below:
1. Type the IP address of your router in a web browser.
2. It will prompt you for a user name and password once connected
3. After logging in you will have a control panel of setting up different settings in your router.
4. The IP address, and default user name/password are different on every route
Note: 192.168.1.1 is a pretty common address for most routers.
5. Check the manual that came with your router for that info.
I also provided a few links below of password lists of different routers.
Click Here
Click Here
I hope this information will be helpful. Thank you for using FixYa!
Your feedback is greatly appreciated.
1helpful
2answers
I have a Verizon Wireless DSL Modem/Router GT704WG and I want to know how I configure my NAT type from strict to Open so that I can play Xbox live better with no restrictions
hi,
you can try to follow these steps,hope these works
1. Log into router's IP address (192.168.1.1) and enter password. Select "Advanced Setup".
2. Click on Advanced on left hand menu and select UPnP
3. Check all three boxes in window and click on Apply
4. Close router configuration window and run XBox test again.
thanks and God Bless
I have a linskys EQ-660R ADSL Router and i am trying to make my NAT type open. I've got UPnp and checked all boxes...nothing happened. here i will give u my options on the advanced menu. (Password) (LAN)...
you need to set
wan type to PPPOE for ADSL
ADSL has one IP address coming out of your building to the ISP
How does it connect many internal computers to just one outgoing IP address you may wonder. It uses different port numbers for each computer on the same ip address via a PPPoe connection .
http://searchnetworking.techtarget.com/definition/PPPoE
if still stuck call your isp for help
you will most likely need dynamic IP for the isp ip and DNS /
1helpful
NAT settings
A good reference for you can be found here:
http://portforward.com/english/routers/port_forwarding/ZyXEL/P-660HW-D1/eMule.htm
Click on Network > NAT > Port Forwarding. Set up the range of ports, and call it Xbox or something. Or, you can disable the Firewall, but I wouldn't recommend this. Hope this helps!
2answers
Xbox
Heres a link to a guide which should guide you step by step to obtaining an "OPEN NAT" status
yeh guide.
otherwise purchase "Compatible Xbox 360 Live " Hardware which will give you a Open NAT
list here
To be honest i think this NAT status is a marketing idea on MS part as NAT is Network address Translation , which is the ability to supply computers on the network a Private IP address using the same Public IP Address , and this sounds like port forwarding, but nonetheless goodluck :)
1helpful
3answers
Change NAT to open
Ok kids... all you hve to do is log in to your belkin 54g at http://192.168.2.1
Find out what ip address your xbox is using and then Click on the DMZportion of your settings on the left hand side of the page.
Enter the xbox's ip address and click the enable box.
Click apply.
Your NAT will now be OPEN!
Cheers!
313helpful
32answers
Change NAT to open
I have this router and have just enabled the NAT settings from Strict to Open:-
4. Close router configuration window and run XBox test again. Worked for me!
Top Zyxel Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
