Hi, the Panasonic t.v. more than likely has more than one kind of output. One of them should be actually lit up with a red glow around the edges, that is the fiber optic digital sound output. It's called a" TOSLINK" connector and is plugged into a matching jack on the surround sounds rear panel. The t.v. may also have a "LINE OUT", " T.V. AUDIO OUT " or " FIXED AUDIO " output this may be in the form of a small 3.5mm stereo headphone jack ( i still call them 1/8 in. plugs) this you can plug into the surround sounds line input on the back panel. If the line input on back of the theater system is rca just use a stereo headphone plug to rca adapter. I hope this helped and thanks for choosing FixYa, good luck-Prodzilla
Your regular TV set must be able to process the surround encoding through its output to where the Durabrand is taking the sound from.
Also, if you are using the TV set on a converter, Cable Box, or Sat receiver, and you are not taking the output from the component output there will be no surround from the source.
Surround sound is critical to how it is processed and applied.
for your dvd player you just go from audio out on the back of the dvd played to the audio in on the surround sound. and you would do the same for the tv if it has an audio out. your surround sound shoud have more than 1 audio in. and then when you swicht from tv to dvd you might have change the channle, setting, source, or what ever it might be called on the surround sound. and if your tv does not have a audio out contact me at [email protected] and i try to help you. hope that works :)
This depends on whether you have digital cable box or not. If you have a Digi Cable Box look for the red/white RCA output and connect this via RCA cable to the Red/White Audio input on your surround.
If just Basic Cable look for a red/white audio output on the back of your televison. connect this to the Red/white in on your surround. Could be called tv in or auxillary.
