This sounds like a driver problem. You probably have an install program for an earlier operating system. I suggest you go to the Technika web site and go to Support then Downloads. Identify your webcam and download the driver for your operating system. For example, the web cam may have worked just fine on a PC running Windows XP, but now you have a new Windows 7 pc. You must go get the Win7 driver for your USB Technika web cam
1. You possibly will need to go to the manufacturers web site and download the the latest drivers for your Lifecam which may not be backward compatible with your operating system (Windows). 2. If you are running Windows 7 you may want to run the "compatibility wizard" to see if your camera's software will run in another Windows operating system mode Ex. Windows 98 or XP \ I hope this helps. Have a great day
Go to your computer's manufacturer's website or the web-cam manufacturer's website and search for the web-cam drivers for your computer model and operating system. Download the proper driver setup and run it, this will install the software for you to use the web-cam.
try turning off your firewall and install it and you may have to disable your anti virus off to, if you still need help just reply to this post and will give you more instructions will need to know what operating system you are using and what operating system is on the disk. You may have to download the right version off the net.
go to logitech web site and look for full driver program for your model of webcam. ...download it and install. ...that should put in every file you will need to run your cam....if you installed the drivers from a disk that came with your cam. then uninstall those drivers first then reinstall drivers from logitech site. ..you might have just gotten a bsd install and need to reinstall drivers again. ...but not from the disk. ...download from logitech site
Here is the link to the software for your web cam. All you have to do is click on which operating system you are using, then click save the file and save it to your desktop so you know where it is. Then just run the software before you plug in the web cam. During the install it will tell you when the program wants you to plug in the camera.
Don't forget to rate this a fixya when your all done, If you need more help feel free to contact me any time. I will even call and provide free phone support. Hope this Fix's Ya!
1.) insert the cd that came with the web cam
the auto run will start,
2.) connect the web cam and follow the on screen instructions this will do the work for you,
incase you dont have the cd, sometimes windows has the drivers that it need so you can just connect it, If windows does not have the drivers or you lost the cd
1.) get a program like driver magician www.drivermagician.com or www.phazeddl.com ( search it there)
3.) install and run the program, this will detect, download and install the drivers for you.
good luck and let me know if you need further help
This fix will work for all of the VEO Stingray problems because it
gives a good driver download site and it tells you step by step how to
get your cam to work with VISTA Good Luck and let me know if this fixed
your problems.
1.Go to this site and download the driver you need: http://www.softsci.com/veodrivers.htm
2.Download it to your desktop
3. Don't unzip, install, or plug in your cam yet
4.Search for this in your start menu: Program Compatibility Wizard
5. Of the three choices click the one that says look for the program manually
6. Choose the option for XP
7. Choose the 680 x 420 or whatever it is not the 256 colors
8. Choose to run as administrator
9. Click next and it should change your screen to a real big resolution and then it will start to install the driver
10. Go through the install wizard
11. After it has loaded plug in your camera
12. Try a program that it is supposed to work with
13. Finish the Compatibility Wizard
now everything should work for your cam. This works with all of your programs that vista will not run.
