Nikon Coolpix 5000 Digital Camera Logo
Anonymous Posted on Nov 12, 2011
I have a coolpx 5000 when i put a 2 gig card in it read but had pics on i didn't want i formated it in my pc and now it won't read any ideas on how i can get the camera working again?
  • Anonymous Nov 13, 2011
    easy to say only format in camera after its allready done how can i repair now that it has been?
Anonymous
Level 3:
Brigadier General:
  • Master 11,967 Answers
  • Posted on Nov 13, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
11967
Questions
0
Helped
2200453
Points
38521
Never format a camera memory card in a computer.....always in the camera!
    Just format the card in the camera....all will be fine.
  • Anonymous Oct 26, 2012
    What happens to the memory card when it is formatted in a computer. If it does not work in the camera again, replace it?
I have a nikon coolpx L100 yes a sd card in it but it puts pic i take on the internal storg &tells me it is full. i have bought 2 new sd cards but it still does it how can i get it to read the card?
Is this information not contained in the manual ? If you have no manual, you can download a manual for almost any equipment by Googling the make and model followed by the word Manual, then follow the appropriate link(s).
1helpful
I have a 32gb memory card that when put on my laptop says no pictures are there and when you put it back in the camera it says no pics on card but when you go to see how much gig is left there is 3 gig of...
what format is the sd card in ? most common is the sd card its self I have had loads that have just packed in and just keep asking for it to be re formatted. also some cameras will take the card and load pic's onto it but its in the wrong format as the cad is in exfat file and not in fat32. some laptops don't read exfat and you need to update so it can read it.
2answers
Card in camera reads "card error". Won't pull
First try cleaning the tiny gold contact points on the card with a small pencil eraser, or a cotton swab with a small amount of rubbing alcohol on it. Next, if the card is still unrecognized, you may need to use recovery software with your PC to recover the pictures. In that case, recommend trying the corrupted card procedures at this link.
Hi my name is beth, I have an A1455 that evidently has a problem with the card slot. Every time I put a card into it. I get an error message "card error" I have put from a 2 gig to a 8 gig in it...
Sometimes, "card error" simply means that you need to format the card in the camera. This will erase the card so download any pics from it first using a card reader if necessary. typrice_87.jpg
Jan 13, 2011 • GE Cameras
1helpful
My polaroid dvf 130 camcorder won't connect to my computer.the software it came with says it doesnt need a driver since I have windows xp what should I do?
this is what i did, and it worked perfectly. go out and get a sd card * any gig u want* as soon as u put the sd card into the camera, FORMAT IT!!!!. do that before u do anything else. don't format it on ur pc or laptop. format it on the camera. if u do that it will work perfectly. i don't know why it wasn't in the manual to format sd card first. but if u try to take pics first, that will mess up the entire system and u will be assed out a sd card. it took me 3 sd cards to figure this out. the cards worked fine but not in the camera. then i formatted it on the camera first and it works fine. the other sd cards i use for other things, i won't discard them but they won't work in the cam. but remember again GET NEW SD CARD AND FORMAT THE CARD IN THE CAMERA FIRST.
1helpful
I have a Toshiba 8 GIG memory card. I used it
When you removed the card from the computer, did you remember to use the "safely remove hardware" procedure? Also, you should never wait until your card is full before downloading...you run the risk of the card becoming corrupted. Your options now...1. Get a separate card reader and see if you can download your pics with it.2. If not, take the card to a store like Walmart that has a Kodak Picture kiosk machine. Insert your card and you should be able to see all your pics. From there, you can make a cd of them. Then, format your card in your camera to return it to factory specs.
1helpful
Fugi S5000 2gb xd M+ Computer says it's not formated
Yes, it would appear that you solved your own problem. The Fuji S5000 apparently only takes the max of 512 mb card. I own a newer Fuji S700 and it works fine with a 2 gb SD card, but I haven't tried anything bigger. Your best bet is to see if you can exchange those 2 gig cards for 512 mb cards at the store where you purchased them, and then try the 512's to see if your pc will read the pics. Explain to the store what the problem is and they should allow you to make the exchange.
1helpful
Format and Check SD card
Purchase an inexpensive card reader such as the Ativa, available at Staples and Office Depot for $9.95. Put your memory card with the photos on it into the reader and plug it into a USB port on your computer. Windows will recognize it as another drive and assign it a drive letter. Using any graphics program, or Windows Explorer, navigate to that drive, open the file containing the pics, click select all, and copy the pics to a file on your computer. Make sure that all the pics have transferred or copied to the new file. Replace the card back into your camera and format the card so it is empty and ready to receive new pics. FYI: Less than 1 gig memory cards are available on ebay for dirt prices. Also, go to the camera manufacturers website and see if they have a firmware update for your camera that allows larger than 1 gig cards to be used. I had to do that for my Fuji S700 so I could use 4 gig cards. It used to max out at 2 gigs. If this has solved your problem please rate it accordingly. Good luck.
2helpful
4answers
Card Error
!. Formating any card in a PC makes it unsuitable for camera use.
2.The camera model may not support 8Gig.
In each case tghe remedy is READY THE BLOODY MANUAL.
2answers
New SD Card wont work - all the others I have do!!
I believe any SD cards larger than 2Gb are technically SDHC cards, which are not compatible with all cameras. Kingston is a decent company so I'm guessing it's not because the card is a dud. If your camera doesn't advertise SDHC compatibility then I don't think you can get the card to work in it.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
