Haier HDN455 Dehumidifier Logo
Anonymous Posted on Nov 11, 2011
Light comes on says tank is full. But it won't start
The tank is empty but the full light stays on
The full light normally comes on when the tank is full. Emptying the tank and re-installing the tank should allow the system to reset. However, if the tank isn't pushed in all the way... the full switch and indicator light will be fooled into reporting a full condition. My suggestion is, first pull out the tank, look at the float and the tank full switch. Become familiar with these two items and confident that 1) the float is not stuck in the up position; 2) the tank full switch that the float is supposed to actuate will toggle (press your finger against it and let it return.) After this exercise make sure the tank is seated all the way in place. If your issue is mechanical, its easier to fix than if it's electrical, and if it is electronic... (just pray that it isn't).
Hi I have problems with my mitsubishi dehumidifier Oasis Elite MJ-E-142NX-A1 The water tank full light stays on even though the tank is empty. I have emptied the water and replaced the container care
Sounds like your float is stuck in the full position, or the sensor that shows full is stuck on full.
If tank is empty but shows full, problem lies where full signal is coming from.
1helpful
DEHUMIDIFER WONT START
empty the tank, and clean the dust off of the condenser in the front or clean the filter. if it still won't turn on, may have a bad sensor or a siezed compressor.
My Kenmore Dehumidifier wont turn on. There is power to it ,all the indicator lights are on, it just wont start. What's wrong?
Check the over fill switch in the tank. If this is stuck it thinks the tank is full and won't come on. After that your compressor may be bad or the starter for the compressor. The Dehumidifier is basically a small air conditioner that condenses moisture in the air then it drains into the tank.
1helpful
2answers
Full light won't go out and it won't run
Hi and welcome to FixYa, I am Kelly
Most likely the sensor assy has failed. See section 6 of this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5520042&diagram_id=28700153#d28700153
Detailed View: ($18.04)
http://www.appliancepartspros.com/part_details.aspx?part_id=4652359
This senses water and humidity levels.
Thanks for choosing FixYa,
Kelly
The bucket full light won't go out and the
Try resetting the bucket, making sure that it is set properly and triggers the safety lever/switch. If that doesn't solve the problem. Turn the Master ON/OFF Switch to OFF, unplug the unit from the wall outlet and wait 12-15 minutes. Plug the unit back in and turn the Master ON/OFF Switch to ON. If the bucket is installed properly, the unit should revert back to the original factory settings.
Hope this helps solve the problem.
I have a FDL70S1 Dehumidifier. Unit runs for just a couple minutes and shuts off-blinking bucket full even though no water in bucket. Unit won't stay on
Dont spend to much time trying to repair dehumidifier they are very cheap to replace. Most dehumidifiers have lots of problems because they are made so cheap. Just replace the dehumidifier you will tank me in the end.
9helpful
3answers
My zenith zd309 light keeps blinking but the water
If the unit is titled forward at all, the "full bucket" "trip switch" will not trigger off as it should. Be sure the unit is on a flat, level surface, or leaning backward slightly--this also aids drainage through the drain tube, if that's your set-up.
The bucket is empty, but when I plug it the full
I thnk your tank is askew. Adjust the osition of the tank until the light goes off ...
Full light comes on early
Most dehumidifiers rely on a float sitting in the pail to rise, turning off the switch. Check and see if the float moves clean and smooth, and is sitting in the pail rather than resting on it's brim.
There may be other safety switches, like a temperature sensor to turn it off if it runs the risk of freezing up or overheating.
Top Haier Dehumidifiers Experts
ZJ Limited
ZJ Limited
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
