I bought my blackberry 9800 torch in other country and as i came to uk it doen't work. Apparently it was bought in UK from vodafone. i tried to make a call but as soon as i dial a number ar starts connecting it hangs automatically up. Can please anybody advice me what should i do? thank you very much.
You can Unlock your Blackberry 9800 torch with imei unlock code. it is very simple and eaisiat way to unlock your Blackberry 9800 torch. get your Blackberry 9800 torch Imei Unlock Code . and use any gsm sim card.
i hope this will help you .
I also have the same problem then my friend told me that you need to unlock your mobile then i visit this third party link and i resolved my problem
http://www.howtounlockblackberry.org
You Blackberry is locked to specific network in order to use other network sim card you will need to unlock it,You can get unlock code at cheapest rate by BLACKBERRY TORCH 9800 UNLOCK CODE provider with instructions.
VISIT: www.blackberryunlockcodes.org/
THANKS ! ! !
1 - Switch ON your Blackberry 9800 Torch with your current network/service provider's SIM card.
2 - Using the menu go to Settings Menu -> SIM card and press select.
3 - While holding the SHIFT key, type mepd.(NOTE: You may not see any text appear on the screen while typing mepd)
4 - You should now see the five locking categories listed.
5 - While holding the SHIFT KEY, type mep2.(NOTE: You may not see any text appear on the screen while typing mep2).
6 - Release the shift key.
7 - You will now be prompted to enter the Network MEP code. (it will also state how many attempts left)
8 - Enter the Unlock Code.
9 - Enter Return/Enter.
10 - The Blackberry 9800 Torch should then be unlocked.
