I have a 2000 V Star 1100 Classic. I just bought the spy 5000m remote start and need help on what wires to tap into. Location/wire/color. I also have herd that on Yamaha you need a relay for the remote start. Please give detail instructions on this install. Thanks
SOURCE: 2002 Yamaha V-Star Classic 1100 Will not run over 70 MPH
The first thing you need to check is the air filter. Sometimes critters can get into the airbox when a bike sits for awhile. Sounds crazy, but it has happened to me. If nothing is blocking the filter, give it a quick clean since you have it out.
Next things to check:
Faulty diaphragm
Improperly adjusted fuel level
Clogged or loose main jet
Faulty fuel pump
You may not be able to check these on your own, but these are the next likely culprits.
Hope this helped
SOURCE: Wiring diagram
if you pull off your headlight you will see which wires go where, blue is normally the running light feed.
SOURCE: where is the oil filter on my yamaha V-star 1100
On the right side of the bike (right side when ou are sitting on it) just above the rear brake lever behind a small circular plate. remove the plate and the oil filter is inside (you will easily see it). Warning---on these bikes you have to drop the front exhaust header and right floor board in order to change the oil filter unless you install a after market oil filter relocation kit. If you plan on changing your own oil it is highly recommended to install this relocation kit.
SOURCE: Yamaha 1100 Drag Star 2001 Custom motor starter,
These parts are fairly reliable. Rather than buying new, you should be able to pick one up from a motorcycle breaker who will post it to you. I would expect to pay about £60-£100 tops in the UK (Depending on mileage). ANy Yamaha dealer will be happy to order you one new, but they are a hell of a price!
SOURCE: Can Synthetic blend oil be used with a Yamaha 1100
Yes, Yamaha makes regular,semi-,and full synthetic oil for there motorcycles. Make sure the oil you use is JASO MA certified for motorcycle use. Do not use any oil that says energy conserving, it will shorten the life of your clutch and drive gears. Amzoil and Mobile 1 both make good motorcycle oil (full synthetic). Full synthetic is often the same price as semi-synthetic.
