Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
Kenmore oven 790-4658-9500 aftercleaning the pannel the f11 code started buzzing only way to stop it is to turn it off on the breaker
Cleaning top of stove then started to clean the control pannel where clock and other things are and the f11 code started buzzing it is a self cleaning oven about 3 to 4 years old
    Scholar:
  • 195 Answers
Unplug unit and wait a few min's then plug it back in it should clear the codes
Posted on Nov 30, 2011
6ya staff
SOURCE:
How to stop buzzer, having mistakenly triggered self cleaning b y moving locking device on door. cannot see a STOP button
Hello Elayne;
My name is Peter. I am a retired field service appliance technician.
You did not provide a model number, which is located on a label on the top edge of your oven door when you open it.
So, I can not be exact.
Reboot your oven control system - Turn the power to your oven off at the breaker box. Wait 10 minutes and turn the breaker back on.
That is all I can suggest until I have you model number.
Posted on Mar 17, 2015
Mar 17, 2015 | Kenmore Ovens
How to fix frigidaire wall oven beeping error message f11
Good Morning Friend,
I understand that your Frigidaire wall oven is beeping and showing an F11 error code. Typically an F11 error code states that there is a shorted key, or a button has been detected as pressed for a long time. I suggest hard resetting your appliance, by cutting the power at your homes circuit breaker for 3-5 minutes. While you are resetting your oven, make sure to wipe down the control panel. The panel is very sensitive and could be detecting something that has splashed or spilled onto it, even dust. When you bring power back to your appliance you will need to start by setting the clock. Turn your oven on any cycle at any temperature. If you are still receiving an F11 error code, I suggest contacting your local authorized technician for further assistance. Hope this is helpful.
-Best Regards-
WP
May 14, 2014 | Frigidaire 30 in. Electric Gallery Series...
I get a F11 code with beeping noise and the oven controls won't work? what can i do?
Hi Ken Kazemi - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if it proves to be ineffective contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
Feb 03, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work f11 code
Hello steve o - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if the error code does not clear contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
Nov 12, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Top oven control panel malfunction. While broiling then switching to bake, door began to lock, I open door before it could complete lock, now "door locked" keeps flashing & I can't...
Hi, One thing you can try is turn off and pull out plug. If you can't get at plug turn off breaker down on pannel for 1 hour and them turn back on. if that does not fix it call repair man. pc board maybe at fault.
Jun 11, 2011 | Kenmore 41389 Electric Double Oven
Kenmore double oven flashing "door locked"
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 16, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore ultrabake lights up when stove top is on but wont heat up
Hard to know...First thing I'd check is the power supply to the unit.  Turn off both breakers.  Check wiring all the way through for tightness.  Turn both breakers on.  Next, you'll need to check the elements for continuity...with the power off.
Nov 28, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Oven beeping
hi my kenmore stainless steel black top keeps making a beeping sound and says F11
Sep 03, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Oven
I used the self cleaning mode for 2 hours and the error f2 keeps flashing and beeping, I did try to power off with the breaker and left it off for about a half hour and it still continues to beep and flash f2, what should I do?
Aug 07, 2008 | Ovens
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
352 people viewed this question
Top Kenmore Ovens Experts
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
