anthony Posted on Nov 11, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Display reads protect after 3 or 4 sec - Audio Players & Recorders
Anonymous
Level 3:
  • Master 8,546 Answers
  • Posted on Nov 11, 2011
Anonymous
Master
Level 3:
Answers
8546
Questions
Helped
2767665
Points
24828
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on; or it may turn on but produce no audio to the speakers.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as another possible root cause for intermittent shutdown.
H4 error code is shown on AC display what can i do to slove this problem
Full list of Gree Air Conditioner Mini Split Units Fault Codes. When error codes appear on the Gree air conditioner indoor display, this tells the user there is an issue with the Gree AC unit. The error code displayed will inform you of the issue or problem that is occurring with the air conditioner. Knowing what the error code means and its definition will help you to understand and troubleshoot the exact Gree air conditioner part that needs to be fixed, cleaned, repaired, or replaced. You can then clean, fix, or replace the Gree part yourself and save money. See below for all error codes that can occur on Gree Mini Split AC's.
Gree Mini Split Air Conditioner Error Codes - How To Fix
Gree Viero AC Mini Split PDF Owners and Troubleshooting Manual
GREE DUCTLESS AIR CONDITIONING & HEATING SYSTEM INSTALLATION MANUAL
Gree Mini Split Air Conditioner Part Names and Locations
INDOOR AND OUTDOOR UNIT
The Gree Air Conditioning Vireo System has onboard error code diagnostics. The outdoor unit will provide status indicators and the indoor wall unit and remote control will display error codes. The following is a summary of the codes with explanations...
GREE AC DIAGNOSTIC ERROR CODES
Gree Vireo Mini Split Air Conditioner Error Code F0
Refrigerant Leakage Protection
1) Refrigerant leak(s).
2) Indoor coil temperature sensor not calibrated.
3) Refrigerant flow is restricted (ex. valve, exv, debris)
Outdoor Unit Red Light Indicator - 9 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code E1
System High Pressure
1) Over charged with refrigerant.
2) Blocked or dirty outdoor coil.
3) Extreme outdoor ambient conditions
Gree Vireo Mini Split Air Conditioner Error Code E2
Indoor Anti-Freeze Protection
1) Low return airflow.
2) Indoor fan speed is too low.
3) Indoor coil is blocked or dirty.
Outdoor Unit Yellow Light Indicator - 3 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code E4
Compressor High Discharge Temperature Protection
Please refer to the malfunction analysis (discharge temperature, overload) in service manual.
Outdoor Unit Yellow Light Indicator - 7 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code E5
Overcurrent Protection
1) Supply voltage is unstable.
2) Supply voltage is too low and system load is too high.
Outdoor Unit Yellow Light Indicator - 5 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code E6
Communication Malfunction
1) Communication cable is wired incorrectly between indoor and outdoor units.
2) Indoor or Outdoor control board malfunction.
Outdoor Unit Yellow Light Indicator - Continuous On
Gree Vireo Mini Split Air Conditioner Error Code E8
High Temperature Resistant Protection
1) Incorrect refrigerant charge level.
2) Refrigerant metering device malfunction.
3) Compressor malfunction.
Outdoor Unit Yellow Light Indicator - 6 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code EE
EEPROM Memory Malfunction
Control board malfunction.
Outdoor Unit Yellow Light Indicator - 11 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code C5
System Configuration Malfunction
1) No jumper cap inserted on the control board.
2) Incorrect or damaged jumper cap on control board.
3) Indoor and outdoor units are not compatible.
Gree Vireo Mini Split Air Conditioner Error Code Fo
Pump Down or Gathering Refrigerant Status
Optional Service Mode
Outdoor Unit Yellow Light Indicator - 17 flashes and 1 sec Off
NOTE: All of the Gree Air Conditioner Model Numbers below are applicable for the error codes on this page...
Gree AC Vireo Models: VIR09HP115V1A, VIR12HP115V1A, VIR09HP230V1A, VIR12HP230V1A, VIR18HP230V1A, VIR24HP230V1A, VIR30HP230V1A, and VIR36HP230V1A.
Gree Mini Split Air Conditioner Error Code Charts
Gree Mini Split AC Remote Control Button Names
Gree Mini Split AC Remote Control Icons Display Screen
Gree Mini Split Air Conditioner Air Filter Cleaning Procedure
Need help with error codes on your Gree AC? Please leave a question below and we will be happy to help.
How do I get the fault codes up on a Panasonic split air conditioning system CUE24FKR
14.2.2 To Make a Diagnosis1 Timer LED starts to blink and the unit automatically stops the operation.
2 Press the CHECK button on the remote control continuously for 5 seconds.
3 "- -" will be displayed on the remote control display.
Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
4 Press the TIMER ? or ? button on the remote control. The code "H00" (no abnormality) will be displayed
and signal will be transmit to the main unit.
5 Each press of the button (? or ?) will increase error code
number and transmit error code signal to the main unit.
6 When the latest abnormality code on the main unit and
code transmitted from the remote control are matched,
Power LED will light up for 30 seconds and a "beep" sound
(continuously for 4 seconds) will be heard. If no codes are
matched, Power LED will light up for 0.5 seconds and no
sound will be heard.
7 The breakdown diagnosis mode will be canceled unless
pressing the CHECK button continuously for 5 seconds or
operating the unit for 30 seconds.
8 The LED will be off if the unit is turned off or the RESET
button on the main unit is pressed.
Diagnosis
display Abnormality / Protection control Abnormality
Judgement Emergency operation Primary location to verify H00 No abnormality detected - Normal operation H11 Indoor / Outdoor abnormal communica
tion > 1 min after starting
operation Indoor fan operation
only • Internal / external cable connections
• Indoor / Outdoor PCB H14 Indoor intake air temperature sensor
abnormality Continue for 5 sec. - • Intake air temperature sensor (detec
tive or disconnected) H15 Outdoor compressor temperature sensor
abnormality Continue for 5 sec. - • Compressor temperature sensor
(detective or disconnected) H16 Outdoor Current Transformer open cir
cuit - - • Outdoor PCB
• IPM (Power transistor) module H19 Indoor fan motor mechanism locked 7 times occurance
continuously - • Indoor PCB
• Fan motor H23 Indoor heat exchanger temperature sen
sor abnormality Continue for 5 sec. O
(Cooling only) • Heat exchanger temperature sensor
(detective or disconnected) H24 Indoor heat exchanger temperature sen
sor 2 abnormality Continue for 5 sec. - • Heat exchanger temperature sensor
(detective or disconnected) H27 Outdoor intake air temperature sensor
abnormality Continue for 5 sec. O • Outdoor temperature sensor (detec
tive or disconnected) H28 Outdoor heat exchanger temperature
sensor abnormality Continue for 5 sec. O • Outdoor heat exchanger temperature
sensor (detective or disconnected) H30 Outdoor discharge air temperature sen
sor abnormality Continue for 5 sec. - • Outdoor temperature sensor (detec
tive or disconnected) H33 Indoor / Outdoor wrong connection - - • Indoor / Outdoor supply voltage H38 Indoor / Outdoor mismatch (brand code) H50 Ventilation motor abnormality 7 times occurance
• Ventilation motor H51 Nozzle lock abnormality 2 times occurance
continuously - • Nozzle H52 Limit switch abnormality - - • Indoor PCB H97 Outdoor fan motor mechanism locked 2 times occurance
within 30 minutes - • Indoor PCB
• Fan motor H98 Indoor high pressure protection - - • Air filter dirty
• Air circulation short circuit H99 Indoor heat exchanger anti-freezing pro
tection - - • Insufficient refrigerant
• Air filter dirty F11 Cooling / Heating cycle changeover
abnormality 4 times occurance
within 30 minutes - • 4-way valve
• V-coil F90 PFC control 4 times occurance
within 10 minutes - • Voltage at PFC F91 Refrigerantion cycle abnormality 2 times occurance
within 20 minutes - • No refrigerant
(3-way valve is closed) F93 Compressor rotation failure 4 times occurance
within 20 minutes - • Compressor F95 Cool high pressure protection 4 times occurance
within 20 minutes - • Outdoor refrigerant circuit F96 IPM (power transistor) overheating pro
within 30 minutes - • Excess refrigerant
• Improper heat radiation
• IPM (Power transistor) F97 Outdoor compressor overheating protec
within 10 minutes - • Insufficient refrigerant
• Compressor F98 Total running current protection 3 times occurance
within 20 minutes - • Excess refrigerant
• Improper heat radiation F99 Outdoor Direct Current (DC) peak detec
tion 7 times occurance
continuously - • Outdoor PCB
• Compressor
Note:
"O" - Frequency measured and fan speed fixed.
The memory data of error code is erased when the power supply is cut off, or press the Auto Switch until "beep" sound heard following by pressing the "CHECK" button at remote controller.
Although operation forced to stop when abnormality detected, emergency operation is possible for certain errors (refer to Error Codes Table) by using remote controller or Auto Switch at indoor unit. However, the remote controller signal receiving sound is changed from one "beep" to four "beep" sounds.
3 of my 5 phones say "No Line"?
This sounds like a registration problem, the errant
handset(s) and the base have lost identification
with each other.
NOTE: the CS6429 works a maximum of 5
handsets, so you have a "fully populated system".
You will have to clear each handset ( I ) then clear
the base of all registrations ( II ) before re-registering
each handset ( III ).
( I ). First de-register each handset ---
0. Start by taking off the battery compartment cover.
1. press [menu]
2. scroll up/down to "Settings"
3. enter * 7 8 9 0 #
4. scroll down to "next page", press [select]
5. scroll down to "Register Clear?", press [select]
6. display asks "Confirm?" or "Register Clear??",
press [select]
7. display reads "Ok" and chirps, press [ off ]
8. UNPLUG THE HANDSET BATTERY
(this is why the cover was off)
9. Wait ~30 seconds, re-connect the battery &
replace the cover
10. display reads "Not Registered"
( II.) To clear the base of all handset registrations
1. press [Find Handset] on the base and hold
past ~4 sec when the "In Use" lamp lights, at
about 10 secs the "In Use" lamp will begin to
blink. 2. release the [Find Handset] button momentarily,
then briefly press it again. After a moment,
all handsets that were registered to the base
(if any) will display "Not Registered" and be
ready for fresh registration ===============================
( III.) To register each handset to the base:
1. press [Find Handset] on the base and hold for
~4 sec until the "In Use" lamp lights.
2. press # on the handset and set the handset into
the handset cradle on the base
3. within 30 seconds or so, the handset will either
chirp and display "Handset Registered", then
"Handset #x" or it will say "Registration Failed".
NOTE: the battery must be well charged prior to the
registration process, a weak battery may cause a
"Registration Failed". Charge the battery for a
few hours and try the registration ( III ) again.
Good luck !!
2answers
How do I get the "change oil" message off my 2008 f 450 superduty?
Message center cluster
#1 press and release setup button until mess. cntr. displays"press reset to begin system check"
#2press and release reset button until cntr. displays"hold reset if new oil"
#3press and hold reset button for 2 sec. and release oil life should read 100%
#4 center displays"setup menu hold reset"
base cluster
#1 press and release trip/reset button until mess. cntr. displays"setup menu hold reset"
#2press and hold trip/reset button 2 sec. until mess cntr. displays"reset for system check"
#3 press and hold trip/reset button 2sec. until mess. cntr. displays"oil life XX% reset if new"
#4 press and release trip/reset button until mess.cntr.displays"hold reset if new oil"
#5 press and hold trip/reset button for 2 sec.and release to reset to 100%
#6 mess. cntr. breifly displays oil change set to 100%.
HOPE THIS HELPS
I have a STR DE 485 reciever. When I try and turn
unplug,leet capacitors discharge, check back of unit where speaker wire clips are to make sure there are no wire strands touching each other,check same thing @ speakers, try turning unit back on.
2helpful
Cant sign into the router inteface try it 3 times
HI! the router interface setup is password protected, the only way to remove the password protection is by reseting the router, by pressing it for 10 secs at the back of the router..
Lamp indicator flashes red 3 times every 5 secs.
Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
2helpful
Just bought refirb. Onkyo 805, hooked up front l&r plus sub and getting no sound. I set up am and fm as per manual and connected a cd changer thru the cd in via rca cables. Radio shows a signal but no...
After few sec when you turn on your receiver did you hear a click noise ? if yes your receiver is OK not in protection mode if no click noise is output protection in that case you must return where did you buy for service and update firmware a lot of update
However you can reset your receiver and debug the DSP section ( digital signal processor ) as follow
To reset
1. Press and hold down VCR/DVR button, then press STANDBY/ON button when the unit is Power on.
2. After " Clear " is displayed, the preset memory and each mode stored in the memory are initialized and will
return to the factory settings, and turn to Standby mode.
Now turn back on and check if it work or not and make sure check input mode such as analog or coaxial or optical input if stil no sound then debug DSP as follow
To set in DSP debug mode
1. Press and hold down DISPLAY button, then press STANDBY/ON button while the unit is powered ON.
The version number of m icroprocessor is displayed only for 3 seconds.
Main:
8 1.05/07903A
2. Press TONE+ button within 3 seconds above, the version number of 1st DSP is displayed.
DSP 1st:
SR8051:07601A
3. Press DISPLAY button while the 1st DSP version is displayed. The status of DSP and DIR will be displayed.
E1A48K0N/0FFPo
FFFFFF0 0 000
To exit
Press STANDBY/ON button.
Then unplug the unit for 30 sec then plug in it should work now if not you need to return it to 1 of the service center Onkyo in your town to repair it
Good luck
5helpful
Shutdown protection? HELP please
All of the Denon recievers I have repaired (over 100) that shut down after a very short time are going into protect mode. The display lights up and after about 10 seconds the display goes out and the standby led blinks red.
I have found that they have one of 3 possible problems and they all require that the reciever be taken apart and fixed at component level. No way to tell what your problem is until it gets put on a bench and troubleshot.
Problem 1. This is the most common problem. One of the front channels shorts out. On the big heat sink the front channels are at each end. It is the front left channel (close to the display) This requires that the output transistors be replaced as well as some driver transistors and some resistors and a capacitor. Lots of work for a blown channel. Denon has put out a bullitin to upgrade the bias transistor and change a couple of resistors to help compensate for this failure. That channel overheats more than any other channel.
Problem 2. There is a resistor that is right next to the preamp board that opens up. It is a 10 ohm 1 watt resistor and when it opens, it causes the unit to go into protect.
Problem 3. The +12 volt regulator fails. It is in the power supply area on a smal heat sink right next to the -12 volt regulator. Generic part number is KIA7812 It also causes the unit to go into protect.
Most decent repair shops can fix these from about $120 up to about $200. Depending on which problem it is and how fast they are at finding the problem. Most charge labor by the hour.
 Grubhead
Grubhead
SmartAviator
SmartAviator
