To brighten the screen of your lattitude laptop you can press Fn key and up arrow key and to decrease the brightness you can press Fn and down arrow key.
the screen wont go off unless you use a docking station. Once you are docked, you can close the notebook lid and use the machine like a desktop: with all your cables hooked into the station itself.
Remove Any Docking Stations or Port Replicators From the Computer Note: Docking stations and port replicators are optional equipment. If you are unsure if you have a docking solution attached to your computer, refer to Table 1 and Table 2 for examples. To remove the docking station or port replicator, perform the following steps: Shut down the computer. Remove the docking station: Universal Docking Stations: Disconnect the docking station's USB cable from the computer. D/Port or D/Dock: Remove any cable locks from the security slot on the right side of the docking station. Move the slide lock forward to the unlocked position. Press the Eject button and lift the computer from the docking station. C/Port II or C/Dock II: Remove any cable locks from the security slot on the left side of the docking station. Pull the locking lever forward until it stops to eject the computer, then slide the computer out of the docking station. Dell manufactures the following docking stations and port replicators (Table 1): D-series DocksC-series DocksSpecialty Docks D/PortLatitude? C/Port IIMedia Bases D/DockLatitude? C/Dock IIInspiron? Advanced Port Replicator Table 1: Dell Docking Stations (Click an image to enlarge it) Universal docking solutions are also available from third-party manufacturers including, but not limited to, the products below (Table 2): TargusKensingtonBelkin Table 2: Universal Docking Solutions (Click an image to enlarge it) Reseat the Keyboard Connector to the Motherboard Caution: Before performing any of the procedures in this section, read and follow the safety instructions in Dell Knowledge Base Article: "Precautionary Measures for Personal Safety" Article ID: 339031. Reseat the keyboard connector to the motherboard. Be sure to handle only the connector and not the cable. For information about how to open the chassis and remove, reseat, and replace components, please refer to your Online User's Guide and browse to the Replacing and Removing Parts section. Remove All Power Sources and Reset the Computer Remove the battery and disconnect the AC power adapter from the computer. Note: For information about how to open the chassis and remove, reseat, and replace components, refer to the Online User's Guide. Click Systems, then the make and model of the computer. Download the Owner's Manual or User's Guide and refer to the Adding and Replacing Parts section. Press and hold the power button for 10 seconds. Reattach the AC power adapter to the computer. Power the computer on. Replace the Internal Keyboard
STEP: Toggle the Video Mode with the <Fn> and <F8> Keys Additional Information Press the <Fn> and <F8> keys to toggle the display mode between the video modes (LCD Only, Monitor Only, and Both). STEP: Determine if an external monitor is being used. Additional Information Determine if an external monitor is connected to the docking station. STEP: Determine if the video problem occurs outside of the docking station. Additional Information View the LCD panel on the system to determine if the same video issue occurs while the system is outside of the docking station. STEP: Remove Any Docking Stations or Port Replicators From the Computer STEP: Unplug All Accessories From the Laptop Computer Additional Information Unplug any accessories from the laptop computer, such as PCMCIA cards, external mice, external keyboards, external serial or parallel port devices, external monitors, external USB peripherals and port replicators.
Do you have an external monitor for use when the laptop is on the docking station? If so, does your laptops screen come on when it's not docked?
If you're using an external monitor while the laptop is docked, make sure that the screen selection is for external monitors, by pressing/hold the FN key and then press the F8 key to cycle through the choices between LCD, Monitor/LCD or Monitor only.
Turn the machine off and press the eject button on the dock. If you locked it then you need to turn the key for it to come out. The eject button usually has a picture of an up arrow over a horizontal line.
You will need to dock the closed laptop first, then use the power button on the dock to turn it on. This will result in the output to the monitor. Alternatively, if you have the laptop open, you can toggle between the laptop LCD and external monitor (or both) by holding the blue Fn key (on the laptop keyboard) and pressing F5.
Best regards,
torgo
