Does it say ERR NO FILE? If so, then read on. The reason you have this error is because you don't have a folder on your sd card named MUSICDAT. Solution:
Insert your sd card into computer
Make folder called MUSICDAT.
Then, transfer all files inside the folder (make sure your songs are in MIDI format).
Safely remove your sd card.
You're ready to put it in you Casio Keyboard!
If you still get the error, take time to read you manual. Read the "using the sd card" part. The folder name might be different for your Casio Keyboard (because mine's a CTK-5000).
...and IF you still get the error, perhaps the songs you meant in your question are MP3 songs (like the ones you play on the iPod)? Then, that's a different topic... :)
Well then, good luck!
I recently added four songs to my sd card and put it back in the garmin gps. They would not show up in the list of songs. The little tab on the side of the sd card must be in the down position. That solved my problem.
what that means is that some of the songs are formated different and the player cant interface with the format. i have a phone with a mp3 player intergrated to it all the songs will play on the phone , but i take it and put in my other dvd/mp3 player and all the songs play except for 2 i figured it out the 2 songs are formated different. so the only way to fix this problem is go on your computer and re download the formated songs like the 15 that work. please rate this
you cant expect all mp3 players to play as many songs as u wnt. each mp3 player has a limit of memory card that needs to be attached. see whats the maximum memory your mp3 player can support. and also see if you can locate all the songs when the SD card is connected to your computer
