Ran Norton virus scan yesterday no issues. Defragged yesterday. I had music playing then unit froze, completely unresponsive, did a forced shutdown. Now it powers up but I get nothing no display, no sound and keyboard is unresponsive. Power button is lit up and mother board (green light) is on...
SOURCE: emachines ET1641-02W constantly freezes because of Norton360?
could be the website your going to
doubt it's your hard drive unless it does it all the time
also do a virus scan
SOURCE: power supply replacement for emachine et1641-02w
i just bought a emachines as well and i noticed when purchasing a new video card that it required a 450 watt power supply, so i went to check and see how much the one i had just purchased had and of course it was 250! that is soooo low, anywho, what i am sayin is if you think that you are going to add any drives or a after market vid card then yes you need to replace the powersupply in ur emachines with at least a 500 watt, they are like 50 to 100 dollars at tigerdirect
SOURCE: Nothing on my Emachines computer will turn on.
I would recommend rechecking your connection to the motherboard. All wires from the power supply to board and making sure the front panel switch connection are correct. Also, make sure the power supply is compatible to the motherboare. even though a 20-Pin ps will connect to a 24-Pin board, it still does not work. Good Luck
Franklin
C2Solutions
SOURCE: The power button no longer works. IS the
i think your power supply has blown, take it to a computer store and ask them to replace the power supply then your problems should be over but you could just ask them to transfer computer box and that should also fix your problem because most boxes have a power supply in them. a small test you can do before that is get a switch open the pc and connect it to the mother board (without soldering it) if it turns on it is the switch then you buy a box if it doesn't make sure you dont use a toggle switch if you use a small hold switch and it wont turn on get a new box.
SOURCE: My t2200 emachine has power,the fan on the cpu
Could be a RAM error. try cleaning the contacts of the memory module before re-inseirting it, or you can try and swap with another if its available
