try www.freeadjunction.com>wiring>wiring-dia
I found that site by going google and typing---schematic diagram for wiring a flotec 5182 pump
there are other sites if that is not suitable
impeller
screws off to the left. on most motors you can use a 7/16 wrench to
hold the rotor still as you unscrew the impeller , go under the
thermal limiter switch, its by the ground screw . you will need to
wiggle it in to get past the wires .. use back of
screwdriver handle to install white portion of seal,. do not touch these
shinny parts with you fingers ! or the screw driver ! prime the pump
with water after every repair, don't starve the pump for water, if you
do watch for the wet spot and replace the shaft seal ASAP ! .. jay your local pool pump motor repair guy in longwood Florida .. home of the pool pump repair puppy, the sign of a bark'n good deal
Same pump, same problem. H/D sells the pumps, but no parts. Here's a link to a vendor of Flotec parts. http://www.pumpvendor.com/Flotec_Parts_List.html
you would have to contact flotec----there should be a part for it,, depending on the age of it, they change the covers all the time to get people to have to replace the whole unit
Contact flotec directly for impeller tollfree 1-800-365-6832
or they may have been acquired by Pentair so try PENTAIR WATER STA-RITE INDUSTRIES 200 Tate Street Union City, TN 36261-024 (800)-800-468-7867 (FAX)-800-390-53
