Click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select hope this helps you
check now start or you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
click start click on computer then right click on your kingston usb drive select format
Thanks to Brian Sullivan for his suggestion. I finally figured out that, magically, 5.4 GB on the drive was unallocated. After I initiated and formatted the unallocated portion, I merged the two partitions; problem solved. There is a life lesson here. I wasted two days on a $17 drive. Again, thanks to Brian Sullivan for his response.
Andrew Christie
