THE LINK Download the sansa updater and you will get the manual and Media
CONVERTER and any new firmware updates.. Then connect it to the computer and run the sans updater
The purpose of booting into recovery mode is to see if the track pad is still acting up. If the track pad is operating normal in recovery mode, then it might indicate an issue with your operating system. If the trackpad is still having issues in recovery mode, it would indicate that your trackpad issue is a hardware issue and it will require you to take it into Apple for further diagnosis.
You will want to try to put the device into recovery mode and perform a restore. You can follow Apple troubleshooting article HT1808 to walk you through putting the device into recovery mode. NOTE: Check for any backups before you put device into recovery mode as you will not be able to backup once it is in recovery mode. If the device has been jailbroken and recovery mode does not fix the issue the hardware has been damaged by corruption and should be replaced.
How to Fix an iPod Touch Stuck in Recovery Mode With a Free Program An iPod Touch's "Recovery Mode" is for alleviating major operating system issues. Recovery Mode rolls back your iPod's operating system, stripping problematic updates and downloads from the unit. The goal of this total system recovery is to revert the iPod to a stable, usable version. Before you use Recovery Mode, exhaust other troubleshooting methods. In some cases, Recovery Mode is triggered automatically after a failed system update or system restore. When it goes into Recovery Mode automatically, you cannot use your iPod until you complete the recovery process. You can get your iPod Touch out of Recovery Mode using Apple's free iTunes software.
Things You'll Need -Apple iTunes-USB cable
Instructions 1 Turn on your computer and open iTunes. If you are prompted to download any new iTunes updates, install the updates before proceeding. 2 Plug an iPod USB cable into your computer. Do not plug the other end into your iPod Touch yet. 3 Turn off your iPod Touch. If the iPod Touch is already shut down, skip this step. 4 Press and hold the Home button on your iPod Touch, and plug the other end of the USB cable into your iPod Touch. 5 Release the Home button after you see a white USB icon and the iTunes logo appear on your iPod Touch's screen. At this time, a pop-up should appear on your computer screen, explaining that the software has detected an iPod in Recovery Mode. 6 Click "OK." 7 Click on the iPod Touch from underneath the "Devices" heading on the left-hand side of your screen. 8 Click on the "Home" tab, and then click "Restore." Once it's restored, your iPod Touch goes out of Recovery Mode and you can start using it again. The restoration process takes a few minutes. Do not disconnect your iPod Touch until a prompt appears, letting you know the system restored successfully.
plug the player into a computer that has zen software and it should then come back out of recovery mode , try to stop player playing when you are finished with it so it doesnt keep going to recovery mode
Recovery mode won't help you unless you have the recovery files to go with it.
Most likely you will need to re-install the firmware on to the device.
Download this "recovery tool" from the SanDisk website and run it with your device connected in recovery mode. Make sure you select "format" when prompted.
Tool is here; http://sandisk.com/assets/file/downloads/firmware/e200fw01.00.12.exe
Recovery mode - power off device. Slide "hold" switch into hold position. Press and hold "record" button and then connect to PC.(keep record button pressed until after connected to pc)
Hope this helps.
