Hi there Diane OE on your display relates to the water draining system (water is not pumped away). the diashwasher is not seeing the water drain away. Dishwashers start by draining before they take on fresh water. Start your dishwasher and listen for a pumping noise from the waste pump if you dont hear any noise it may be the pump is blocked or faulty. please advise if this helps kind regards gary.
Hi
OE in your dishwasher is a
drain error and dishwasher not draining issue usually occurs due to kinked
drain pipe, clogged drain filter or drain pump. First make sure that the drain
is not clogged and remove clogs if present. If no visible lint is present then
remove the lower front access panel to check the drain filter and drain pump
for any clogs, you'll need to clean the drain filter and drain pump completely.
Also, check for any food pieces stuck near the pump impeller & clean the
chopper assembly. If the issue
returns after cleaning then the drain pump assembly should be replaced. Hope
this helps...please post back for further assistance.
Daniel
