LG LHD65EBL Dehumidifier Logo
Lorn Janz Posted on Nov 07, 2011
I need a circuit board (MFG # 6871A20600B)for an LD650SY8 dehumidifier. I need it in canada.
Where in north bay on. can I purchase a replacement filter for my kenmore 36 dehumidifier?
Hello, Mike -
You MAY be able to find the right filter to order for your Kenmore dehumidifier on the website PartSelect Canada:
https://www.partselect.ca/
or on the website Easy Appliance Parts Canada:
https://www.easyapplianceparts.ca/
or on the ShopBot Canada website:
https://www.shopbot.ca/m?q=Kenmore+dehumidifier+filter
Best wishes.
Dehumidifier Thermistor
there is NOT...
By your model number...
I bounce off of a lot of other (subsequent models (I presume))...
But your model does NOT resolve to any serious parts
USA domestic suppliers... not even good drawings!!
I tried appliancepartspros, easyapplianceparts, repairclinic, partsselect & searspartsdirect.com
Got spanked pretty good... Looked at related circuit boards... but none had any significant detail to determine a THERMISTER
FROM... Do not match
Time to get the ACTUAL NUMBERS OFF OF your thermistor...
and go to electronic houses... eBay, grainger... even RadioShack
In my humbled opinion...
FAD504DUD ENG10 12 FAD704DWD Dehumidifier Display Circuit Board Frigidaire...
Water Filters Lawn Garden Appliance Parts
PartSelect Appliance Parts and Repair Help
Find Your Appliance Parts
Have had a little over a year went turn on and does'nt have power to main circut board but no further can this board be replaced
Hello friend, thank you for your post!
From my understanding your Frigidaire dehumidifier is not showing power to the circuit board. I would recommend reaching out to your manufacturer to see if they could provide any further assistance since you advised the board cannot be replaced. Hope this information is helpful. -Matt
I have a delonghi des 14 dehumidifier. Usually it goes into pause mode for 3 mins when you first turn it on with the yellow light on and then starts dehumidifieing.It now stays in the pause mode forever...
Just fixed this problem with my DES14. Its a fault with the circuit board inside the machine and is very easy to fix, even for a novice. Here is how to do it:
1) Open up the machine by removing the screws in the case. (Make sure it is unplugged!)
2) Locate the circuit board on the side of the unit.
3) At this point you have two options. If you want a unit with full functionality you need to buy a replacement circuit board. I found one on MasterSpares (http://www.mastersparesonline.com/product/index/10147) It costs about 30 pounds. Simply remove the old board and replace it.
4) If you want a working unit for no extra cost (but without the functionality of the humidistat) then remove the rectangular white connector from the circuit board which has red,blue,white and yellow wires entering it. Add an extra wire between the central white wire and the red wire that is adjacent to the yellow. (see photo).
5) Re-assemble the unit. If you have opted for the free option the unit will work when you plug it in and switch it on but will no longer cut in and out with different humidities (or have the annoying warm up period). Thankfully the water overflow cut-out will still work.
Hope it works for you! Feel free to ask if you are confused!
Need new circuit board Crcfd2514-040
HI, you can purchase this Board by clicking the link below. it will direct you to an online parts store. you can purchase the Board at this site location as well if you wish.
CLICK HERE
1helpful
Dehumidifier won't run
After all that testing you have diagnosed the problem. It is the main circuit board. So there is not reason to do any more test. I would just get a new control board and off you go
2answers
CIRCUIT BOARD
I've replaced mine twice.  water pools under the board and shorts it out.  I raised the mounting points this time around.  I found the board at Appliance Parts 866-312-3498
Fedders Dehumidifier - Wont Turn On
Looks like a control board, Check the board for burn marks. What model do you have? Some parts are available on-line at appliance factory parts.. also check your Capacitor and fan motor before you install your new Board..Let me know if this helps? Krazytech
3helpful
3answers
Dehumidifier doesn't turn on at all.
This dehumidiifier has an inherent design problem. There is a control printed-circuit board mounted above the cold coil, sitting in a shallow plastic well. The moist air eventuall condenses in the well and shorts out the board. I have found this on 2 units now. You can order a new board on line and it installs with just push on wire connectors. That will fix the unit but I suggest you mount the new board with longer screws and spacers to raise it out of the well.
Won't Power On
This reply does not solve the problem, however my MAYTAG M7DH
45B2A DEHUMIDIFIER had the same problem.
Circuit Board COR 268BV1.O had circuits burned (on lower side of
board). The circuits that showed signs of arching were the right end
of D1, D 2, D3, D4, and at C2, C3, C4, C5, J1, O1,.
Apparently water must have entered the area and shorted these circuits. But I do not know. The only alternative is to replace circuit
board or junk it
MY LAB
Top LG Dehumidifiers Experts
ZJ Limited
ZJ Limited
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
