SOURCE: KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
First look to see if the ignitor is coming on. Most common problem is the ignitor is weak or just bad. When the power is applied to the ignitor it glows and builds up resistance to open the gas valve then it lights. If the ignitor is weak or bad it will not build up enough resistance for gas to come into the burner. One sign of this would be a "woosh" sound when it trys to light. If the ignitor is coming on but not lighting it is most likely the ignitor is bad. Should have a full glow. Also, if the ignitor looks whiteish in color this is a sign of it going bad. You can compare to the broil ignitor to be sure. If the ignitor doesn't come on at all will need to see if you have power to the ignitor. Let me know what you find and let's solve it before you rate the solution.
SOURCE: Oven burner pulsates
The gas regulator valve would also be my first guess. It seems to not be allowing enough gas into the system. When the top is on, only a small amount of fuel is required, and when properly mixed with the air all is well, but when you also put on the oven, the regulator won't allow enough gas into the system, so it's "burning lean". I'd get it fixed before it pulsates so bad that it actually blows out the flames and you're left with a propane smelling dangerous house.
SOURCE: self cleaning oven directions
Press the self-clean button. The panel becomes blank(---), then press the up arrow( ^ ). The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning. Good luck, ya'll!
SOURCE: Kenmore Ultra bake self cleaning oven is showing code E0 - F2
My oven will not stay on, when started to preheat it will come on for a few seconds and they it will make a beeping noise and the codes E0 F2 will appear. The codes stay on even if the oven is off.
SOURCE: F1 when bake on oven is 350 degrees.
You also have a defective electronic control. Replace the clock.
