GE JVM1850 1000 Watts Microwave Oven Logo
A
Anonymous Posted on Nov 06, 2011
Beeper wont shut off - GE JVM1850 1000 Watts Microwave Oven
Level 3:
  • GE Master 17,130 Answers
  • Posted on Nov 07, 2011
GE Master
Level 3:
Answers
17130
Questions
0
Helped
3633060
Points
52372
Remove the power plug and Allow the voltage present on the board to drain OFF. After an hour please recheck and if the beep still stays there is fault in the motherboard. Possible that the beeper driver is short and is continuous. If all the other functions are working without any issues, all you can do is to cut off the beeper connection if you are able to remove the board and snip off . Attempt with power plug removed .
Sharp model smc1132cs disable beeper
The buzzer is responsible for beep,it is mounted on PCB assembly,either remove the same or cut the supply sourse to it.
Beeper problem
wither it fell out of place or needs replacement
1helpful
Spacemaker xl (1999)low volume beep
According to the owner's manual (available here), there is a beeper volume on some models in this series. If yours has one, press it and then press 0 to 3 to control the volume (0 mutes the beeper and 3 is loudest).
If your model doesn't have the beeper volume control it's just that the beeper is going bad. They sometimes do that, getting faint or quitting entirely. You can't get a replacement beeper from GE, only the entire control circuit board.
The beeper is a piezoelectric type. Radio Shack sells a variety of beepers. If you know someone who can replace electronic components, they may have one that could be used on the board. Changing the beeper for one not the same as the original would not affect the oven's operation or safety, so that's an option. I'd do that myself if I were repairing this for a friend. But you might not be able to get a professional service shop to do this because of liability concerns. They would most likely replace the entire board.
With luck, your oven just has the volume down. Hope this has helped, and thanks for using Fixya!
The beeper will not shut off on my advantium 120 m/w
Is there a code "F3" in the display too?
That would mean the key panel (part number WB27X10467 key PCB assembly) is shorted.
The service manual is here if you or someone you know want to check it out and possibly do the work.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Can I shut off the "beep" on my "LivingHome" microwave P70D20AL-
I have the same problem, I'm trying to figure it out as we speak. I'll reply if I find anything out.
Intermittent reminder beeper won't shut off
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes. Then let us know if the hard reset does not fix it.
Loud horrible beeper
It's a safety device, mounted inside.
Clock timer volume too low
The beeper sound level can be adjusted.
Press the "BEEPER VOLUME" pad on the keypad, then select 0–3 for mute to loud.
Your owner's manual is here.
16helpful
4answers
Disabling the beep on a Kenmore microwave
I have Kenmore microwave model 721.61820100.
It has an "Option" button. Press it. The display say "NUMBER"
Then press "1". The display should say "SOUND" and then "OFF".
Press "Start" and that beast turns silent, well not really, but the beeps are goooone.
If for some reason you don't like it this way repeat the sequence and the sound this time will turn "ON".
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
