Question about Craftsman 4 Cycle Blower/Vac
My craftsman 32cc leaf blower won't stay running
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 184 Answers
Check age of gas. Cannot be more than 30 days old.
Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage.May need to clean or replace carburetor.
Posted on Oct 18, 2013
6ya staff
SOURCE:
Anonymous
  • 48 Answers
SOURCE: fuel mixture for 32 CC McCulloch leaf blower
simple enough prob - go to any local mower repair shop or hardware store and buy the small bottles that you mix with 1 gal of gas - all 2 cycle engines can use it - it makes life so much easier-
Posted on Oct 17, 2008
kachbibi1
Bill Dickerson
  • 979 Answers
SOURCE: craftsman leaf blower/vacuum
I have a Craftsman and you should have a separate attachment to it. Your motor will turn the same, instead of pushing air out the pipe, you will draw air in through the air intake.
Posted on Feb 03, 2009
Anonymous
  • 163 Answers
SOURCE: gas blower craftsman leaf older modle
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. check the primer bulb for pin holes and seating/sealed properly. if that doesn't work have the carb repaired at a service center or replaced.
Posted on Nov 30, 2008
Anonymous
There is a round grille on the bottom of the unit. Insert a flat blade screwdriver into the latch to release it and reveal the vacuum opening. You should have a two-piece intake pipe that will attach to the opening.
The collection bag attaches to the smaller outlet where the blower pipe used to be (unscrew the wing nut to release the blower pipe). The bag clips onto the hooks at the base of the opening.
Posted on Apr 24, 2009
Anonymous
  • 110 Answers
SOURCE: the cord pulled out of my 32cc craftsman blower.
slow and steady, there is no shortcut for that machine, find a clean work space and start at the top. They will never win an engineering award for that one
Posted on Nov 17, 2009
Craftsman 32cc/170 mph leaf blower. Why does it die after a few minutes running?
Is this a consistent situation? Starts, runs then dies after a little while?
If so, sounds like carburetor/fuel pump (which is a one way diagraphm) issue.
Take carburetor apart, and also obtain a rebuild kit for it. Clean it well, compressed air through all the jets, replace the parts from the kit and reassemble. Re-install back onto unit.
Also... Replace Spark Plug, fuel filter and clean the spark Arrestor screen at muffler.
May 26, 2015 | Craftsman Garden
358.797991-32cc
you need to clean the carb. out good
Dec 02, 2012 | Craftsman Garden
I have a Craftsman 32cc blower/vac model #358.797251. Replaced fuel lines and primer bulb. Getting fuel but won't start
Check for spark and air filter in good shape. Make sure bulb side gasket is OK! No leaks! Good luck!
Oct 16, 2012 | Garden
Need a diagram for replacement of fuel line on a blower/vac model # 358.798980
Hi jfkunz
I think this is what you are looking for.
Please rate me
Bud
Oct 12, 2012 | Craftsman Garden
I have a gas craftsman leaf blower/vac 32cc. it starts ok but it wont shut off. what can I try?
Hi, W/D here.
There should be a switch at the front of the machine that you can depress to break the power and shut the machine down. Most of these type switches will go to off only as long as you hold the switch down, then return to the run position when you let off of it. Take a closer look, and you should see it.
Best regards, --W/D--
Apr 07, 2011 | Craftsman Garden
I have a Craftsman model 358.797920 32cc blower want to know the mixture of gas per twocycle oil?
Most of these mix at 50 to 1. 500ml of oil to 5 gallons of gasoline should do it. If you don't feel comfortable with this mixture try 40 to 1.
Nov 17, 2010 | Craftsman 4 Cycle Blower/Vac
The cord pulled out of my 32cc craftsman blower.
Nov 16, 2009 | Craftsman Garden
Craftsman 4 Cycle Blower/Vac Logo
2,934 people viewed this question
Top Craftsman Garden Experts
john h
Sheldon Dedek
rjivaro
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
