I've connected my old HD as a slave via IDE cable to the IDE port on the MBO. Worked fine. Then I bought one of these: http://www.vesalia.de/pic/ide40sataconv.jpg. Connected it to HD's IDE connector, connected attached power cable (goes to the white port on the adapter), and plugged SATA cable from the adapter to the SATA port on the MBO. Windows XP x64 won't recognize it. Does this HD (or its IDE port) support SATA at all, perhaps that is the problem?
SOURCE: Seagate Barracuda 7200.7 ST380011A
Hi, your query, "is there a way to fix it?" if you intend to use if again normally, afraid no way; if you want to recover/retrieve important data/files, probably: 1. seal the drive in a sandwhich ziplock plastic bag, leave it in your freezer overnight, install as a secondary master in another PC, autodetect in CMOS, if detected, boot to your OS, copy whatever you can real quick, soon as it reaches ambient temp chances are it will no longer be readable again; or 2. assuming it is an electronic problem, using a torx driver remove the pcb, get hold of another hd of same brand & model, borrow the good PCB and tempo use it, again install as secondary master in another PC. if no available 2nd HD at hand, install and while in CMOS autodetect HD, feel around the PCB components and determine which heats up faster than the others, spray it with a contact cleaner, if detected continue to your OS to back it up, continue spraying to maintain lower temp; 3. assuming mechanical problem (though highly unlikely) lightly tap with a small rubber mallet (rubber coated handle of a side cutter will do) bottom of drive and install; 4. assuming an electrical connection problem, reheat the 4 power terminals at the bottom (+, gnd, gnd & +) and/or remove the pcb and check/clean contacts at the back of the PCB and its mate, 2 sets; 5. assuming you can do component level soldering and can use a VOM, check surface mounted fuses on PCB near power connector. All of the above are last resort and are not guaranteed to revive your HD. Most require that you run your unit open with possible risk to electrical shock. If you are not comfortable, it would probably be to your advantage to seek the services of a qualified service professional. Sometimes it work, sometimes not, hope it be of some help to you. Pls post again how things turn up. Good luck and kind regards.
SOURCE: hard disk I/O error cannot formate harddisk shows no fixed disks how to solve
Please try to check with your cmos system if it was detected, if not means your harddrive was absolutely damage.
Please rate me solved!
Best regards,
Philip
SOURCE: My seagate barracuda 7200 b will not boot up. It has been operating fine for the last 8 months
i suggested you use NORTON DISK DIAGNOSTICS to repair the MBR(master boot record)the master boot record is bad and you can use winXP bootable nto repair the drive by pressing R after booting is completed.but you need to be able to use DOS prompt before you can do this
SOURCE: SECOND HARD DRIVE NOT RECOGNIZED
Change the settings of you IDE drives in your BIOS. Set your secondary boot device to HDD1. Also make sure that your primary HDD is set to master and the secondary HDD is slave. The jumper is found at the back of the hard drive where you connect the power and IDE cables. Try this and post back as to how it went..
SOURCE: SATA HDD make SLAVE
IDE Cable with 3 connectors (you have 1 or need to buy 1) :
- blue: conn to motherboard
- black: conn to master HD
- grey: conn to slave HD
Cable (select:) cable will auto detect with most modern HD's from same type (SATA it was i think) and you need to go to you're BIOS, set up cable select for the HD's. Maybe best to set up master first, not both at same time. If you have a SATA and ATA set up the master first, then other. So if SATA is slafe but it in grey connector, otherwise black. For an ATA you might need a converter cable for the power, most motherboards don't have 1.
Master/Slave designation is determined by jumpers on IDE drives. Most drives have adequate markings on them to identify these jumper positions. If not marked clearly, you will need the manufacturer's data to determine that designation.
If you are curious about a working system just power-up in set-up mode (usually by depressing (f1-or-f2) during boot-up sequence, your system-bios will display this information for you.
