Ovens Logo
Posted on Sep 26, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What does F1 mean on the magic chef oven?
I was broiling something then finished, went to bake something ten minutes later and the f1 started flashing after beeping. I have no idea what happened the burners still work. Christmas is tomorrow no turkey in my oven...does the f1 mean fuse 1?
Thank you in advance. my oven does the same thing...some days it doesnt do it at all but like tonight it is constant. what does it mean and how do you keep it from doing it
  • wandalea Mar 15, 2009
    I replaced both the ERC and touch pad. In 4 months, after the 90 day warranty was obsolete, same problem all over again. Is there another solution? The stove is useless without the touchpad.
Anonymous
Level 2:
  • Expert 116 Answers
  • Posted on Sep 26, 2008
Anonymous
Expert
Level 2:
Answers
116
Questions
0
Helped
54885
Points
249
The f1 error means the something may be wrong with the touch pad on the oven
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Regards
Dont forget to rate this solution
Anonymous
Level 1:
  • Contributor 4 Answers
  • Posted on Jul 23, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2948
Points
9
Membrane touchpads don't like heat or moisture, and especially both at the same time. They suffer from what is called "silver migration", not unlike electrophoresis, the silver ions in the laminations migrate under the constant applied d.c. voltage and form "dendrites". These basically are short circuits to the microprocessor when it sees them it displays the dreaded "F1" error code. It might as well be "FU".
The greedy BAS**** appliance manufacturers KNOW THIS and love to sell $3 parts for $300. The appliance repairmen don't mind it a bit either. Oh, and you usually cant buy just the touchpad itself, you have to buy it and the whole microprocessor control board as one assembly which will set you back around
100-500 of your hard-earned dollars. There is NOTHING WRONG WITH THE MICROPROCESSOR USUALLY, it just sees a bad touchpad with short circuits.
Now the above is bad enough, but guess what, the heat and moisture from cooking activities will cause the same kind of failure in anywhere from 3 days to a year, depending on the quality of the laminations and sealing in the touchpad itself. Most are very cheaply made.
Now you know why the professional ovens and ranges NEVER have any touchpad controls, only the "old fashioned" temp bulb in the oven hooked to a single temp dial control. Rarely goes bad, lasts for YEARS AND YEARS. Microprocessors DO NOT BELONG IN APPLIANCES, they are HOSTILE ENVIRONMENTS and most OEM manufacturers state the humidity and temp requirements for touchpads, etc. which are
exceeded in the range/oven environment, ALWAYS. Demand appliances WITHOUT COMPUTERS.
4helpful
I'm getting a constant beeping sound and a F1
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced
Timer keeps going off at random times and won't shut off. We had to unplug from the wall error F1?
on maytag's a F1 means defective touch pad or control board. google your ovens model number codes.
2helpful
3helpful
2answers
Our magic chef oven starts beeping and gives us a F1 on the display
f1 indicates a shorted touch pad ,if you want to make sure ,unplug unit ,disconnect touch pad from computer board ,if f1 goes away touch pad is bad.if not replace board
2answers
My mom has a Magic Chef oven, model 5892VRV. It
You have 2 choices.
Replace the electronic control(clock).
Or, replace the range.(stove).
Won't heat up
You have two ignitors one for bake and one for broil your bake is not working
1helpful
2answers
Error code F1
I had the same problem and found this post:
http://fixitnow.com/wp/2006/03/11/maytag-amana-jenn-air-and-magic-chef-range-f1-codes/
The oven had been cleaned earlier in the day and the touch pad ribbon connector was shorting. I cleaned it with rubbing alchohol and blow dried the whole board for good measure. Hooked everything back up and haven't had a problem since.
Oven timer goes off when not being used
I have the same problem with the beeping and screen flashing F1 does anyone have a solution yet?!
Top Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Oven Expert? Answer questions, earn points and help others
