SOURCE: bobbin case on my 524fb necchi has come apart
Almost all Necchi use a class 15 bobbin & bobbin case, a new case should cost around 7 to 10 dollars!
Dwayne
SOURCE: necchi sewing machine
www.ifixmachines.com has lots of parts fitted to your sewing machine for a cheaper price
SOURCE: NECCHI, model 4795. Thread bunches up at bobbin.
it sounds like the thred tenshion is to loos or the timing has sliped a little and its off a bit this can also happen with wear on the gears or just a loos fixing letting the timing slip back a bit,
SOURCE: I have a Necchi Royal Series 3205FA. I wanted to
If you have a stop motion dial with little grooves all the way round the best way is to get a wide plade screwdriver, put the plade part on one of the grooves on the left hand side of the dial and give it a thump on top with your hand, that usually does the trick.
SOURCE: how do you wind a bobbin on a necchi 537fa?
You can find instructions at this link. Print them out so you have them handy in case you need them again. :)
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Necchi_Sewing_Machine_Threading/Necchi_536_537_threading_Diagram.htm
