Mike, The static electrical spark probably '
zapped' the Rth230b Honeywell Display unit. If you have already tried removing the power (batteries) from the unit and after waiting several minutes; reapply the power (batteries). If the problems remain unchanged, then it is time to replace the Display unit with a
new one. The static electricity problem is problematic and the only way to prevent the same problem from recurring is to
discharge yourself before touching the Honeywell Display. As you walk across the room which (probably has carpet), causes the static electricity to build up on your body and then discharges itself through the Display unit when you make contact with the Display unit. You might try coming to a complete stop and attempt to discharge the static charge on your body by touching the wall first with one hand for a second before touching the Display unit with the other hand. Naturally, cold weather with low humidity makes the static electricity worse. Hopes this helps
you
. Henry
If you need further help, I’m available over the phone at
https://www.6ya.com/expert/henry_239f63a136de60f0
