SOURCE: installing a honeywell CM900 wireless programmable thermostat
the analog unit uses just two wires for heat. red - white. there is a heat anticipator setting that must match the burner current. check your programmable specs and follow instructions.
SOURCE: Honeywell RTH230B
This my situation exactly. Changing from a 6 wire manual round Honeywell thermostat to a 5 wire Honeywell programable. Is there a way to maintain all functions?
SOURCE: rewire an old 2 wire thermostat to a honeywell 5-1-1 programmable
I connected the blue wire to the R and the white wire to the W on the old thermostat and shoved the new Honeywell 5-1-1 Day programmable thermostat up the first guys *** that i ran into at Canadian Tire
Thanks for your help
SOURCE: unlock Honeywell TB7220U1004 Ultrastat Commercial
Pull off face and remove batteries and reinsert.
SOURCE: The middle of the touchscreen of my Honeywell
it not a touch screen, its manual old style honeywell, square box, not round, not rectanglur.
Testimonial: "It is a touchscreen. I have seen references to the battery being round and lithium CR2450; however, not sure if this is accurate. Does anyone know?"
Would like to help..What is fes settings....what does fes stand for? ...tks
