Hello Brad,
The thermostat is a small diameter appx. 6 inch long round probe it looks like this
To test it for proper functionality ya need to use a multi meter capiable of reading ohms of resistiance...unplug the sensor from the wiring and place the meter leads onto the 2 wire ends of the sensor and at room temperature once the oven has been off check for between 1060-1100 ohms at the sensor if its good,if the ohms value is much higher or lower that 1060-1100 at room temp. the sensor is defective.
GENE
Good Morning James, thanks for your post!
From my understanding your broiler feature is not working on your Frigidaire wall oven and the element is good. It could be a potential issue with the thermostat or connector of wall oven. If there is a miscommunication within the wall oven you may be able to perform a reset to clear the issues. If you would like to attempt a reset you would need to flip the household circuit breaker off for roughly ten minutes. If that does not correct your issue I would recommend contacting a professional technician for assistance in diagnosing your wall oven. Hope this is helpful. -Matt
Hello Bruce Hubley, thanks for your post!
Based off the information you have provided your Frigidaire wall oven will not heat up higher than 400 degrees. It may be a problem with your thermostat or control panel. I would recommend performing a reset on your oven and you can do that by disconnecting power from your oven for roughly ten minutes. If this does not help correct your issue I would suggest having a professional come out to provide the proper repairs on your oven. Best of luck! -Matt
Hello Chris Hammond, thanks for your post!
Based off the information you have provided it sounds like a potential problem with your connector for your element within your Frigidaire wall oven. I would recommend reaching out to a professional technician for proper diagnosis repair to help avoid any unnecessary part purchases. Best of luck! -Matt
