That message is from the automatic updates windows makes from time to time ...and this message usually appears after a fresh install with the operation system out of date ..and if you have the automatic updates ticked for to be made automatically ..The thing to be done is either let it install the updates...and it will shut down by itself...or ..start windows..and go to control panel ..and on the automatic updates...stop the updating process..This will cause a message to appear in the tray system every time ..to warn you that your computer is out of date ..and so ...but it has no real distress cause it will run like a charm even without the updates...(probably even faster ..cause if your computer is a little limited in resources the updates will slow it down a little ..
So ..this message is not a pest ..but the windows updating your operation system ..the only issue is when it is in error and takes more than the time it should ...usually it should not take more than a couple of hours for all 55 updates to be installed ...and this in case you have a slow computer...
