Question about Linksys WRT54G2 Wireless Router
Random wi-fi dropping
My wife as a laptop that is wireless and we both have i-touches we use wi-fi. Every now and then none of our device will connect to the internet through the router. We normally have to unplug the router for it to reset and our stuff will connect. It has been happening for a few months now. I use a Pc that is direct connected to the router and never have a problem. Any help would be greatly appreciated.
  • clifford Nov 03, 2011
    The i touches do have the current OS. The problem is also with my wife's laptop too. I will try your router suggestion's. As far as battery levels go, our devices are usually pretty charged. After i check the router stuff i will get back to you.
  • 3,940 Answers
Go to the linksys website, see if they have a firmware flash for the router, that may help in some connectivity issues. You may also find that the ipad/iphone may drop connections when battery levels are low
Posted on Nov 03, 2011
  • Linksys Master
  • 7,733 Answers
Lots of people seem to have trouble getting iPhones and iPads to connect to WiFi networks. Some blame the phone/pad others blame the router. Make sure the iPhone/iPad has the latest OS/Firmware, its possible something has been fixed with the WiFi code in later OS/Firmware versions. Also if possible configure the router for Manual wireless security rather than the WiFi Protected Setup (WPS) option. I had trouble with some wireless devices using the WPS mode. Couple of further suggestions to try.First reset the WIFI security so there is no security. Do so by logging into the router's administration page, select Wireless from the menu. On the Basic Wireless settings page select Manual and ensure the SSID is set to Enable. Then hit the Save Settings button to save the changes. Once you return to the Basic Wireless Settings page, select Wireless Security from the menu. On the Wireless Security page change the Security Mode to Disable then hit the Save Settings button to save the changes. Then see if your iPhone/iPod will connect to your router which doesn't have any security on it. If it does than you may have to go back and reconfigure the Wireless Security settings and enable security. You may have to experiment with each setting (WEP, WPA or WPA2) to find one that works. Then recheck to see if the iPhone/iPad can reconnect to the router when it has wireless security enabled.Second option to try, is when you scan for the wireless routers with the iPhone/iPad, don't click on the router name and enter the WEP. Instead try typing in the router's SSID name and then select the proper security type and enter the wireless network password.
  • Doctor PC
    Doctor PC Nov 03, 2011
    Many Wi-Fi issues can be resolved by doing the following:
    Basic troubleshooting
    Tap Settings > Wi-Fi and turn Wi-Fi off and then on again.
    Verify that you are in range of your Wi-Fi router or base station.
    Confirm that your Wi-Fi router and Cable/DSL modem are connected to power and turned on.
    Check whether other devices (portable computers, for example) are able to connect to the Wi-Fi network and access the Internet.
  • Doctor PC
    Or read this athttp://support.apple.com/kb/HT4199
6ya staff
SOURCE:
Wii-fi will not turn on
Let me know the device you are using
Jul 13, 2015 | Google Android
Tip
How to Speed Up Internet on my Touch Pro 2?
<p>The HTC Touch Pro smartphone 2 is avaialble for T-Mobile and Sprint subscribers, and uses the data network cell phone to connect to the Internet. While the Internet connection is based on a strong 3G connection for fast browsing, you can also activate the Wi-Fi device to connect to a wireless network. Available Wi-Fi networks within range of the Touch Pro will be displayed on the device are on the list of networks. Once connected, your Internet speed is capable of data based on the strength of the wireless signal to send. <br /> <p><br /> <p>1. Slide your finger on the "Home" screen to the tab "Settings" appears. Play the "Communications" button. <br /> <p><br /> <p>2. Touch "Wi-Fi" on the phone screen, then hit the wireless network is displayed in the "Discovered Networks" list. <br /> <p><br /> <p>3. Type the network security key using the onscreen keyboard, and press "Done" for the network to connect. A wireless signal appears at the top of your phone screen when connected to Wi-Fi network successfully <br /> <p>4. Touch "Back" to return to the "Communications" menu. <br /> <p><br /> <p>5. Play the "ON / OFF" in "communication" from the menu for Wi-Fi off. It is important to turn off the Wi-Fi functionality when not connected to a wireless network, because this mode the battery is not on. <br />
on Aug 09, 2011 | Apple iPod touch
Tip
How to manually enable Wi-Fi on an iPod Touch
<p>IPod touch not only offers a music library on the road. It also has Internet capabilities. The iPod touch can connect to wireless internet connection available and browse the web using the Safari browser included on the device. Typically, Wi-Fi capabilities automatically. But if your iPod touch wi-fi is off, or if you activate it, you can do it using the Settings window. <br /> <p><br /> <p>1. Touch the "Settings" icon on the main screen of the iPod touch. <br /> <p><br /> <p>2. Touch the option marked "Wi-Fi." <br /> <p><br /> <p>3. Touch the "On" next to the setting marked "Wi-Fi." <br /> <p><br /> <p>4. Tap a wireless network list to connect. <br />
on Aug 05, 2011 | Computers & Internet
9" Inch Google Android 4.2.2 Allwinner A23 Tablet PC Dual Core WiFi 8GB UK how do i connect to my television?
You can try this and see if it works for you:
Connect to Wi-Fi networks Some of this information applies only to devices running Android 5.0 and higher. If your device is running 4.4 or lower, the Menu icon looks like this 01640868e1517a345806b8352772a19a6aa8. If your device is running 4.3 or lower, the Settings icon looks like this snp_2918920_en_v1.
You can connect to Wi-Fi networks with your device, as well as add networks you use often or remove networks you don't use any longer. You can also change the settings for saved Wi-Fi networks on your device.
Keep in mind that your device will remember networks you connect to, along with security details, and connect automatically when in range.
Turn on Wi-Fi and connect to a network
  1. Open your device's Settings menu snp_bee8810a5fcd80173673b4b15a1804eaee99_3529219_en_v0.
  2. Under "Wireless & networks," touch Wi-Fi.
  3. Touch the Wi-Fi switch to turn it to the On position.
  4. You'll see a list of saved and available networks.
    • Secured networks display a lock icon 9708aea66a4ca95cd2dda6f363c600366de9 and ask for a password to connect.
    • Your device will remember networks it connects to and automatically connect to them when in range.
    • You can forget a saved Wi-Fi network if you don't want your device to connect to it automatically.
  5. Touch a network name from the list of available networks to connect to it.
    • Android 5.0 or higher: If the saved network you want to connect to isn't showing up in the list of networks on your screen, touch the Menu icon e0c84b16c85d9e9f1f5eb1d0111d3421b872 in the top right corner of the screen. Touch Refresh to reload the list of networks. Touch Add network and enter the network's name (SSID) and other security details, if needed. Then touch Save.
  6. Once connected, your device will say "Connected" under the network name.
Once you've connected to a network, it will show up in your Saved networks list. If you have trouble connecting to Wi-Fi, try the following steps:
Nov 11, 2014 | Tablets & eReaders
Samsung manuals
If plan is enabled:
  1. From the Home Screen, press the Menu Key.
  2. Touch Settings.
  3. Touch Wireless and network.
  4. Touch Tethering and portable hotspot.
  5. Touch Portable Wi-fi hotspot settings.
  6. A message provides an overview of portable Wi-fi hotspots. Touch OK.
  7. Touch Portable Wi-fi hotspot.
  8. A portable Wi-fi hotspot message is displayed. Touch Yes .
  9. You will now be able to share your phone's data connection with a PC or multiple WI-fi enabled devices.
Sep 02, 2014 | Cell Phones
Tip
How to put the Internet to an iPod
<p>Apple's iPod device only with Internet capabilities, the iPod Touch. Other versions of the device can only synchronize with a computer full of music and video. The iPod Touch, however, can connect to wireless Internet networks, where available. Bringing the Internet to your iPod Touch, you need Wi-Fi settings to activate the device. Once you allow them, the iPod Touch Wi-Fi settings will be available networks, you can connect to a tap of the finger to detect. <br /> <p><br /> <p>1. Click the Settings icon on the home screen of the iPod Touch. <br /> <p><br /> <p>2. Click Wi-Fi <br /> <p><br /> <p>3. Click "On". <br /> <p><br /> <p>4. Click a wireless network in the list that appears to connect. <br />
I have an Acer aspire 5610z Just acquired a Verizon MIFI2200 53CF Secure Ability to network 5 wireless computers Was able to configure below not problem IBM T60 Compaq Presario Not the case with...
This method will hard reset the wireless drivers back to default settings, but before you perform this remove power from the modem and router for 2 minutes reconnect power and wait another 2 minutes for them to settle down.
Go to your laptop, right click "computer" select "manage" and then "device manager", a list will populate, then click on the + sign next to "network adapters" and right click on the wireless adapter and "uninstall" the device, reboot the PC and wait for windows to detect the wireless card and install the drivers for it, this will appear in the system tray (bottom right hand side) when its done try to connect again.
Good luck
Aug 03, 2009 | Acer Computers & Internet
Hi, I have an old acer laptop and my wife communicates with me on it using broadband and a router with a usb pick up. I have returned home and have a new acer laptop with wireless LAN already installed. It...
Youe broadband router is working ok with the broadband cable.So it is configured with the broadband cable.Now,to work with the wireless internet,you have to configured the wi-fi router to work internet.You can see the wi-fi connection but unless & untill you will configure wi-fi router it must not work or if before it was working with the wi-fi then you can check the wi-fi router setting because it might change by mistake.Surely it will work after configurating wi-fi router.
Jan 03, 2009 | Computers & Internet
Cannot get ipod touch to connect to wireless network
  • Tap Settings > Wi-Fi and turn Wi-Fi off and then on again.
  • Verify that you are in range of your Wi-Fi router or base station.
  • Confirm that your Wi-Fi router and Cable/DSL modem are connected to power and turned on.
  • Check whether other devices (portable computers, for example) are able to connect to the Wi-Fi network and access the Internet.
Jan 01, 2009 | Linksys Wireless-G WRT54G Router
Wifi issues
i think there is some kind of block from the network administrator
usually you can access wifi easily with out any problems.
di u install any third party application in your phone recently??
Sep 17, 2008 | HTC Touch P3450 Smartphone
Linksys WRT54G2 Wireless Router Logo
300 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
