Question about Lexmark X5470 All-In-One InkJet Printer
X5470 constantly is powering on and off - Lexmark X5470 All-In-One InkJet Printer
  • Official Brand Answer
  • 3,344 Answers
Please try the steps below:
  1. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer.
  2. Disconnect the power cord from the power source. Re-connect after 30 seconds to a different known working power outlet. Bypass any power surge devices or power extensions/strips and directly plug in the cord into the power outlet in the wall.
  3. Re-plug the power supply into the printer.
  4. Press the power button if the printer won't automatically power on.
If the problem continues, please contact Lexmark Technical Support for further assistance. Thanks.
Posted on Nov 30, 2011
6ya staff
SOURCE:
My lexmark x5470 does not turn on, and only a red light bright inside near the print injectors. Thank You.
Try to rebrick you printer by pulling out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds. This will reset your printer.
If that doesn't help, try to plug your printer into a different known working power outlet.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 25, 2011 | Lexmark X5470 All-In-One InkJet Printer
Lexmark x5470 i dont have a power suply cable..,its only a usb cable drectly to the pc...
You can purchase it at most large office supply stores. If you still can't find one, please contact Lexmark technical support for assistance.
May 01, 2011 | Lexmark X5470 All-In-One InkJet Printer
My x5470 shows light on copy mode only and if i try to press some thing else nothing happen
Remove the power supply (black box where the power cord is plugged in behind the printer) with the power cord still plugged in it and other end still plugged in to the power source/outlet. Leave it unplugged for about 10-15 seconds. Then, plugged the power supply back in the printer. Make sure to plug it in the correct position. Hope this helps. If not, place a comment so I can get back on this. Good luck!
Apr 02, 2010 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X5470 powers on and off constantly
I encountered the exact same problem with my Lexmark X5470. After a power failure on Aug 20, the printer would reboot itself every few seconds. I unplugged the power cord and/or adapter for a few minutes and after replugging, it worked fine. However, the problem returns after I power off the printer and then turn it back on, in which case I unplug again for a few minutes. Hope this helps.
Aug 19, 2009 | Lexmark X5470 All-In-One InkJet Printer
Can A Lexmark X5495 use the driver for a X5470 instead???
try it and see most likely it won't work but you could try to upgrade the software.
Jul 01, 2009 | Lexmark X5470 All-In-One InkJet Printer
Suddenly started making a beep whenever it has power.
you may need to remove the old drivers download new ones, re install
www.lexmark.com
May 28, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark x5470 all in one
Good look getting help with this. Mine is out of warranty by 30 days now b/c tech kept screwing around. Don't worry, though, thye'll send you 20% off a new one.
Apr 02, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X5470 All-In-One InkJet Printer Logo
83 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
